Drywall Tips
Drywall Tips
Drywall Tips
John Stump
>Save many hours by using a product called "finishing compound". It comes as a powder that is mixed with water and cures like concrete instead of drying, with cure times available from 30 to 90 minutes. Use self adhesive tape (paper or fiberglass) on joints, then apply a thick coat of compound. It doesn't shrink or crack like mud. The idea is to build out the joint equal to 2 coats of mud, to where a thin coat of mud followed by light sanding is all that remains. It sands much harder than mud, hence the final mud coat. I used to do 3 coats of mud, waiting hours between coats with a large fan running. Now I use finishing compound, a mud coat an hour later, and sand once. Start with small batches until you develop an idea of how well you can work with it and how much you can apply before the cure time is catching up with you. Clean all compound from tools & mixing bucket before it hardens completely. Don't mix a new batch with any remnants of an old batch because the cure time will be shortened. Use a mixer in an electric drill to mix it quickly and thoroughly.
Re: Drywall Tips
Thanks, Could you give us.....
>a name brand and where you bought it? I have been patching drywall for the last week or so and am tired of waiting for the mud to dry. This would change the process from a multi-day process to one you could do in a day. I knew the stuff was out there, I was just waiting for you to save me the trouble of researching it. Thanks.
Re: Drywall Tips
Re: Thanks, Could you give us.....
Gary Evans Tallassee, TN
>Hi Barry,
I would think you could get it wherever you are buying your regular mud. HD and Lowe's both carry it down here.
John wasn't kidding when he says that it sands harder than normal mud, so go easy while you are getting used to it. 3 coats of fast-dry are still quicker than 3 coats of regular.
Gary
Re: Drywall Tips
Hot mud is great stuff....
John in New Mexico
>I prefer the 45 minute, but the 90 will let you mix a bigger batch. I buy it at the borg, or any drywall supplier. US Gypsum and others make it. Stuff at the borg says "easy sand" on the bags. I've bought 20 minute too, but its way to fast. Maybe ok for quick patching or for pro's who work faster and have a helper to clean the bucket (very important to keep the tools and bucket clean).
I usually do two or three coats, trying to get it as smooth as possible. Thin even coats allow you to use more knife pressure and get it smooth. Once its set a little, you can come back and knife off any ridges or globs. If its too soft still, give it another ten min. Last step is a light sanding to blend it into the wall, and you can skip that if you're going to texture it.
Hot mud is a mixture of gypsum plaster, perlite, various clays, and a bonding adhesive. If it had more plaster you could get it even smoother, but it would be harder to sand and work with.
John
Re: Drywall Tips
Re: Hot mud is great stuff....
Paul Woolson
>Is this the stuff that dries to a sort of brown/tan/beige color? Darker where it's thicker?
I used to live in a plaster/lath home that I rewired. Long story short: I had to cut channels up from every recepticle to run the wire because I couldn't fish it between studs. The compound I used to fix the repairs was WONDERFUL. I think it was called QuickSet or QuickFix. But I can't seam to find it anywhere.
Is this the same stuff? Sounds kind of like it.
Re: Drywall Tips
Don't think so...
John in New Mexico
>This stuff dries white, just like bucket mud. Comes in 20# bags, found in the same isle as premixed. I'll take a picture tomorrow if you like.
John
