OT photo switch...
OT photo switch...
OT photo switch...
vlparisian - Houston
>I am in need of photo controlled outlet for a waterfountain. I would like for it to come on early in the morning and run all day and turn itself off at dark. Is there such a thing as a photo control swich that will turn off at night (not on) and on at dawn?
Victor in Houston
Re: OT photo switch...
How about....
Hoa Dinh in Alameda
>a simple timer?
It's not really dawn to dusk, but should be good enough for a non mission-critical task.
-- Hoa
Alan in Little Washington (NC)
>You can either use a timer or buy one of these dusk to dawn replacement photo eyes and connect it to a relay so power is on in the day off at night.
Re: How about....
>I've had lousy luck with timers. Besides, the sun comes up a little earlier each day and sets a little later thru june 21 (or thereabouts) and then starts setting earlier and comming up later until Dec 21 (or thereabouts) I'd be resetting the timer about once a month assuming it was indeed accurate enough to warrant resetting only once a month.
Victor
>Ok. I'm a little dense here (and I just finished a beer), explain Relay? Or will the guy at the big box know what I need?
Victor
Already have the intermatic photo control
A relay is.....
>That photolight switch will turn ON a circuit at night and turn it off during the day, which is what most people want to do with outdoor driveway lights, etc, but the opposite of what you want.
A relay is a small electronic device (think Radio Shack) that will turn on/off one circuit based on whether another circuit if on or off. A good example of a "relay" is in a dust collection system, when you have low voltage 24V wiring to the blast gates switches, and the 24V "relays" the info (on or off) to the relay switch which then turns on/off the 220V circuit to the motor.
You could ask for a "relay" at HomeDepot but I'd suspect they'd give you blank stare.
What you need is a photo relay switch that is made for your application. THey exist. I've seen them. Just can't recall where. One of the electrical supply online stores, just can't recall which.
Happy Woodworking!
Thanks, I've got a Grangers near me
How bout this?
Craig in Silverdale
>Get two photo sensors. Build a box with a sensor(A) in it in front of a light connected to the other sensor(B) which is on the outside of the box. When the sun goes down, sensor "A" turns on the light inside the box. The light turns off sensor "B" which is connected to the water pump. When the sun comes up, sensor "B" turns off the light, thereby turning on the pump until sunset and it starts (or in this case stops) all over again. I think I watched the Honda Commercial too many times.
It could work... :>)
Dennis Yoder
>Get a 120v normally closed relay, properly rated,from radio shack and wire the pump to the contacts of the relay. Attach the photo sensor to the coil side of the relay so that when the relay senses the dark and turns on it in effect activate the relay. This opens the contacts and interrupts the current to the pump. If the photo sensor fails the default would be the pump running constantly. You would need to have some method to remove power from the entire system for servicing. Dennis Y
vlparisian in Houston
>Thanks. Thats going to be my afternoon trip to the store...
I've got the power to the pump issue solved, I'm using a wall outlet so I can "pull the plug" on it should the default become an issue.
Victor - Houston
