Which came first, mortice or tenon?
Gary Evans Tallassee, TN
>I'm in the process of building the new mailbox post. Using mortice and tenon to hang my outriggers.
Is it better to cut the tenons first and make the mortices match, or vice-versa. I already cut the tenons thinking that would be the easiest approach, but now I find that precisely marking the location of the mortice is a bit of a challenge.
So how do the pros do it? I know I've read about this in the past, but this is the first time I've done it in a long while. If it matters, the outriggers are the same width as the post, so if I don't get them lined up perfectly, it will really show.
Thanks,
Gary
Re: Which came first, mortice or tenon?
Mortise first!
Tony - Memphis
Curly Smith
>I've found that it's far easier to match the tenon to the mortise than the mortise to the tenon.
In other words, in the future cut the mortise first.
>Good Afternoon Gary,
I nearly always cut the mortises first, and then fool around with tenon fit. It saves time and temper. A skinney or too fat tenon can always be corrected with a shim or two, or a shoulder plane as appropriate. But a misaligned or too wide mortice can't do a perfectly cut and positioned tenon much good. In some of my disasters, I have even sought refuge in pocket screws. :<)
George
Jesse in New Mexico
>If you are using power tools, the mortise width is pretty much determined by the bit or chisel on your router or mortiser. A tablesaw tenoning jig can make any thickness of tenon. I usually make the tenon about 1/32 thicker than the mortise and sneak up on it with a sanding stick.
If you are using hand tools, then the width of the mortise should be that of your chisel. Same logic, but execution (at least mine) is a little more sloppy.
I would do the mortise first in either case.
>Thanks guys,
I should have asked the question before I started cutting. I'll just put the mortices where they need to go and adjust the tenons to fit.
Gary
