>I am building a China hutch in a Mission style in red oak. My wife likes the look of the fumed white oak. Is there a way to replicate this look on red oak hopefully without fuming? How would I find the ammonia in my area if fuming is the only way?
Olympic oil based "Special Walnut" stain (we found it at Lowes). Wipe on a heavy coat with a rag to saturate the surface. Let it sit for 15 minutes, then wipe completely dry. Let this dry overnight.
Next:
Watco "Medium Walnut" Danish oil (also found at Lowes). Saturate the surface the same way you did the stain, let it sit 15 minutes, wipe it off and let dry overnight.
Then:
Rag on one coat of Amber Shellac (Lowes likely has Zinnser's)
This was published in the latest issue of "Woodworking" magazine. We've also had good luck with General Finishes gel stain. Every time we mention it in print, they change the name of the color, look for "Java" or "Espresso"
Red Oak won't fume as well as white oak. Blue print supply houses have the strongest-26%-be very, very careful-goggles, gloves, respirator, well ventilated area where you can blow the fumes outside with a fan or better yet, build a tent outside to do the fuming. Janitor supply houses sometimes have 12-15% ammonia and Ace Hardware has 10%. Lower concentrations will work, but take longer. You may have to put more ammonia in after 24 hours.
>A industrial chemical house will have the ammonia. They may not be willing to sell it to you though. Number one they normally don't sell retail and number two they could have liability issues if they sold it to you. A blueprint shop would likely have suitable ammonia and a dry cleaner could probable get it. If you have friends in either of those business I would try that route.
>Red Oak can be highly variable in color and it may not be easy to get a match with fumed white oak. White oak can be quite variable in color also. You have to match the stain you use to the specific wood used in your project. No way to do this on-line so the best advice is to test your stain and the rest of your finishing schedule on scrap from your project.
