Jet contractor saw vertical adjustment woes (long)
Eric Kuehne
>Well, after about 8 years of faithful service I am finally experiencing a problem with my saw. If there is one thing that has bothered me about the saw over the years it's that the vertical adjuster is kind of stiff. Well, it's gotten worse recently to the point where the blade wouldn't go down all the way. Now it has failed altogether.
So I checked the manual and it has a procedure for adjusting wear in the mechanism. Well, I was in to the project enough to see if I could figure out the stiffness issue as well as do the gear adjustment. I've isolated the problem to the fit (or dark matter or something else) between the trunnion and the arbor bracket. The exploded diagram in the manual actually shows wave washers between the parts but my inspection indicated that there isn't any room for them. At this point Plan B is to take the assembly apart which means taking the saw and all my add-ons off, disassembling the offending mechanism and customizing the fit with a file. Plan A is to find a better plan. I've tried some penentrating lubricant and it has helped but it's still pretty darn stiff.
Has anyone else had a problem like this? If so, how did you remedy it.
Thanks for wading through this.
Eric in Los Gatos
Re: Jet contractor saw vertical adjustment woes (long)
Re: just needs lubricating?
Chuck W
>Maybe the mechanism needs a touch of oil or grease? After 8 years of use it may be the only problem.
Eric Kuehne
>Chuck,
I tried Dyna Glide as it's what I had around. Seemed to help a little bit but it's not where it needs to be. I might try some WD-40 in hopes that it will penetrate better.
Eric
