Re: Laminate countertop design question
JackLane
>Justin
I build countertops almost every day. Honestly, either way (one piece or two piece)will work. Building it in a single piece, in my opinion, is the most difficult but won't have a seam telegraphing through the laminate. About the only time I do it this way is when I will be using wooden edge. When I build them as a single piece I use a Festool saw and guide to make the cuts. A sled or guide and a circular saw will work just fine. Just take your time and lay it out on the wood carefully. I cut with the top facing up and finish up very carefully in the corner of the 'L' with a jig saw. MDF, particle board, or plywood will work fine. MDF and particle board will stay flat but could cause problems around moisture. Plywood will telegraph irregularities in the substrate through the laminate, but is the more durable surface.
Personally, I'd build that top out of plywood and make it in two pieces. It's much easier to build and keep square. Also it's much more user freindly if you'll be laminating the edge. If you will be using a laminate edge (1 3/8" overhang), sandwich the lower strip of plywood with the main surface and resaw it on your table saw. This will give you a perfectly square surface to attach your laminate edge to. Many would tell you to put your plywood edge at a 90 degree angle to the main surface. That is flatter but you end up with a problem making your edge perfectly flush with the top. That's where you'll potentially get delamination and you don't want that.
Build the 'L' the same way and pocket screw it to the main run. Be careful when you're screwing the two pieces together and try to keep them aligned as well as possible. Sand the joint flush. If you'll be transporting the top, put a plywood scab over the joint underneath to keep it from breaking.
Good luck and hope this helps
Jack
PS. Use a single piece of laminate to cover the whole thing even if you build the substrate in two pieces. Seaming laminate is a whole different issue.
