Melamine Dilema
Melamine Dilema
Melamine Dilema
Ron Hildreth, Alta, Iowa
>For years I have used melamine for such things as adjustable shelving inside cabinets, but was asked to biuld a complete intertainment center out of the stuff! This entertainment center will be 6' long and 51/2' tall, and 12" deep. Yup--tried like heck to talk them out of it, but to no avail. Even warned them about the weight. It's to be used in thier vacation cabin, and "everything else is white,too". Painted, though. They had been to a big box store and saw prefab shelving, and decided they wanted it made out of the same stuff.
My biggest shock was to be told they wanted no visable fastners.
My concern here is I'm afraid just glue won't be enough to hold it together, regardless of the joinery I use. Any of you do anything like this before, and how well did it work? Was it flimsy at all? Has it stood up well over time?
Thanks for any thoughts on this you guys might have to help this skeptical mind of mine!!
Ron in Iowa
Re: Melamine Dilema
No problem here
Hoa Dinh in Alameda
>Most of the things I built for my son - bookcases, desks, computer tables, bookstands, .... - are with melamine banded with hard maple. Sometimes I use white iron-on edge banding instead of hard maple.
It is smooth, clean, and easy to keep clean. Not having to spend a lot of time in finishing (except for the maple banding) is also a big plus.
Built correctly, melamine furniture is solid and durable.
I used to use mainly dados and rabbet joineries, but I started using biscuits for about 2 years now. I use just the common yellow glue. There are no fasteners to show, or to hide.
So far I haven't had any failure yet.
-- Hoa
Re: Melamine Dilema
Re: No problem here
>Thanks, Hoa,
This will be the biggest project I've ever tried use primarily Melamine, so was unsure about the possible outcome. Glad to know it's do-able. Some of it will be biscuit joinery, and some will be dado and/or rabbit joinery. I'll be using the iron-on edge banding, as per the customer's request. Sounds like it will be a fast turn-a-round project!
Thanks for the help!
Ron in Iowa
Re: Melamine Dilema
Re: Melamine Dilema
John McGaw
>No doubt it will be monstrously heavy -- a good reason that similar furniture is sold in knock-down form. But fastening is relatively easy to manage though. I've used biscuits and melamine-compatible Roo glue with no problems at all.
Re: Melamine Dilema
Re: Melamine Dilema
John in Calgary
>And don't forget to use good dust collection or a good dust mask when cutting up that much melamine - my nose ran green boogie snakes for 3 or 4 days and my throat was raw the last time I cut up and dadoed enough melamine for book shelves.
John (who thought he was coming down with a cold at the time, until he did it again a few months later and finally put the pieces together)
Re: Melamine Dilema
Re: Melamine Dilema
Jesse in New Mexico
>If its going into a 'vacation cabin', you might want to make it in small modules or knock-down style for ease of transport and installation. You could plan it so that the fasteners are visible only from the inside or housed in dadoes. If they are going to have heavy equipment, like a TV in it, be sure to provide plenty of support under the shelves.
Re: Melamine Dilema
Re: Melamine Dilema
frank shic
>ron, don't forget to get a hi-atb blade with a -5 or -6 hook as well as a zero clearance insert to eliminate chipout on both sides. the blade will last you for about 10 sheets before needing resharpening. if you use a triple chip grind, you may get a little more mileage but you won't have perfect edges on both sides.
Re: Melamine Dilema
Re: Melamine Dilema - New Tool Excuse!
Joe Dusel (Vista, CA)
>I think your best bet is to buy a Festool Domino. You really need this to put these boxes together. ;^)
Since I unfortunately don't have a Domino I would be forced to use my Maggi 23 spindle construction boring machine to drill for 8mm dowels. They also work pretty well.
Joe
