Changing Planer knives....Mistake
>I have one of the lunch box planers that has knives you can sharpen (Dewalt 733). I have two sets of knives and I sharpen them myself. I got a nick on one set, so rather than grind them down far enough to get rid of the nicks, I decided to swap one of the knives with the other set. I sharpen them both at the same time and as far as I can tell they are Identical, but I was a little worried about "dynamically balancing" the head. I held the knives side by side and I measured them. They appeared to be Identical. I installed them last night. I was tired and feeling run down, wondering if I were coming down with a cold.
Today, I ran a prized piece of quarter sawn heart pine through the planer and discovered that one of the knives was not set right. When I turned the machine on, it vibrated slightly more than usual, but I attributed that to swapping the knives in spite of all my measuring. A number of weird things happened. The feed rollers would not pull the piece through, the snipe was terrible, there was snipe all along the piece and the surface was quite scalloped. It took a minute for the light to go on in my head and I finally looked at the setup on the knives. Apparently I did not properly set one of the magnetic gages and one blade was about a sixteenth ahead of the other.
I had the little depth gage set on the planer and it was not supposed to go below 3/4", but with the knife out of whack, it did.
I reset the knives being more careful. No more vibration. It also turns out the "leading" knife was the one with the nick and it left its little bead. By the time I cleaned up the board I had just under 5/8". Bummer, it was supposed to be the top of my huntboard.
So, there are lessons here. Don�t do this stuff when you are tired and not thinking well. Use good light, the problem was obvious in daylight, but not so obvious last night. Check and recheck. Run a test piece first, a scrap that will tell the tale without ruining something you prize. Pay attention to your instincts. I should have wondered more about the vibration.
Yet another mistake I have made to save you the trouble.
