>While cutting on the bandsaw, the blade jumped off the wheel. It did not break but, there are a few slight "bends" in the blade. Not twists or kinks. Is it done for? Is there a good use for old, dull bandsaw blades?
>Probably. I have bent a couple and was never able to get them to run well afterwards. I tried de-mangling them or un-bending them, Better, but not good enough.
I think you will find it will not cut smoothly and also it may be hard on you wheels and especially your guides. If it is an expensive blade, you could sent it back tot he manufacturer for some TLC. They could cut out the bent parts and replace them with new material, but they would have to sharpen the entire blade to line up all the teeth. Clearly not worth it for a cheap or low end blade.
As for uses, you might make small knives out of the steel, you could try a "chatter tool" if you are a turner, and you can put a bunch of pieces side by side and make a curry comb for your dog or horse. You might even be able to make rasps and paint scrapers out of them. I have a bunch I am saving (pack rat gene speaking here.) for something, I just don't know what.
I sort of agree with Barry. I dispose of the ones I've kinked or bent severely. I have/have had others which are slightly to moderately bent which I have been able to bend back against my thumbs to original shape/condition, and which do not affect the blade guides.
>Yup, Probably toast. One use for toasted blades is to cut them into 2 or 3 inch strips, gang them together, and grind them so they will cut a bead (or other shape of your choice), then attach them to a stick with epoxy and you have a beading tool.
