OT- Washing machine drain hose
Justin Szeliga
>I figured this question, though way off topic, would get answered fastest here. How high can a washing machine drain hose be raised above the washer & still have it drain?Could it be raised to about 3' above the top of the washer?
Thanks
Justin
Re: OT- Washing machine drain hose
Maybe
Tony Shaftel
>Mine is 13" above the top of the washer. I googled 'washer discharge height' and saw some opinions that the washer discharge pump would handle 3' above. The author of one such opinion also suggested the questioner simply try it. What an idea, wish I'd thought of that! If you have a sink or outside door nearby you could just put the longer hose on, set the end as high as you like, and run the washer. A call to a local washer/dryer repair shop that handles your washer brand might work, too.
Nat Robison
>It might but the pump probably isn't designed for it. You might also ask if it will shorten the pump's life and/or void a warranty. Are your drain lines overhead? If so, there are several pump kits that can be attached to a laundry tub. Check HD or Lowes.
Al Stokka - Cambrige, Iowa
>Justin,
I don't think the problem is the pump. Either it will pump to six feet or it won't.
The real problem is likely to be backflow. You'll have six feet of pipe/hose full of dirty, soapy water when the washer says it's time to rinse. That six feet of water will drain back into the washer when the pump stops pumping.
Al
No check valve?
Tony Shaftel
YES
>The drain pump on the machine can easily handle three or four feet above the machine. The Usual technique is to discharge into a two inch line with a trap at the bottom. The two inch line is supposed to be about thirty inches tall to give a small reservoir for the water until it starts moving through the trap and it serves as a vacuum breaker so that water can not siphon back into the machine for the sewer. I see them all the time in basements and they work fine. Some people use a short piece of three inch line for the reservoir and a trap. Just don't fit them tightly together or it might back siphon the sewer. I have never notice a check valve, but you could try it and add one if necessary.
Larry Clinton At Frankfort (Central)., Indiana
>Yes - this rating used to be in your owners / installation manual. I used to install for Sears - Kenmore washers used to be Whirlpool. Some of the very cheap brands had low limits - but I believe 3' was within the range of all units at the time. This information should also be on the web site for your brand of washer. This is a normal installation for city basements. Many of the main drains in this city exit through the basement wall 3 to 5 foot off the floor. With the standpipe and trap installed the rise is often 3' or more.
Re: YES
jared
>Mine is at least 3 feet above the top of the washer and it works just fine. Jared
Yes Sir ! . . .
s.mackay@worldnet.att.net
>I drain mine into one of those plastic 50 gal. drums. To provide air curculation under and around it it sits on a small wood pallet. The top of the barrel winds up about three or four inches above the washer's top deck. I did some experamantation and it seems that, as long as you allow the hose to hang in the same " shape " it came as, you're good. Now you just install a drain fitting in the bottom of the barrel and connect your garden hose. I always feel like I'm beating the system by watering the yard like this and I'm told that phosphate stuff does a grass good as long as you move it around. I'm not a Greenie-weenie just a cheap skate . Leaves more money for tools !
