Homemade buffer Q
Homemade buffer Q
Homemade buffer Q
Tony Shaftel
>I finally got hold of a motor to use for my homemade buffing machine. Next design issue is the size of the shaft that will hold the buffing wheel (driven by the motor via pulleys). I want it to extend out around 8" from the the machine in order to have lots of access to the 8" buffing wheels. Should I use a 3/4" shaft or can I get away with 5/8". 5/8" is more convenient for attaching things, but is it stiff enough?
The buffing units I find on the web (Shop Fox #W1681, caswellplating.com) have 3/4" shafts. Is this really necessary for occasional, moderate use?
Thoughts and opinions would be much appreciated.
Tony
