Finishing panel: What happened?
Dave in Dacula
>This is a maple panel I was finishing for my latest project. As you can see a blotch appeard on both panels, any ideas as to why? Here is the scenario. I sanded both panels to 220 grit; wiped and tack clothed them clean; applied one coat of a Zinsser amber 1 lb cut shellac; next day applied a second coat of the same shellac; 2 days later applied one coat of Bartley Country Maple gel stain, waited a couple of minutes and wiped off the excess; waited a couple of days lightly sanded with 320 grit; wiped with a cloth, then a tack cloth to remove saw dust. At this point everything was perfect no problems at all. I then opened a can of Waterlox tung oil, I started on the left side of the panel (no problems) as soon as I got to the right side these blotches appeared. The panel on the right is not as bad but the same thing happened. This same problem happened about 5 years ago when I used Bartley gel stain (on white oak) followed by Bartley gel varnish; blotches appeared. I have finished many many projects and I have had this only happen twice both times using Bartley gel stain. After I apply the gel stain, all is fine it is only when I applied the oil or varnish that the blotches appear and it looks as if the oil removes the gel stain and leaves only the bare maple. I am very careful when I finish projects I wear new gloves and clean off all residue.
Thanks for reading,
Dave C.
