Re: OT: Water bladder tank capacity "Real Science"
Larry Clinton At Frankfort (Central)., Indiana
>The ratings are accurate as far as I could tell when installing them - I was a Contractor Plumber in Indiana for several years - (second job). These (bladder type) tanks have many advantages over the old water only filled tanks. First, they do not require infusions of air due to the water adsorbing the air as in the tanks without bladders. This allows them to be installed anywhere in the plumbing system. - You can put one (or more) under the sink, at the end of your water line under the house etc. The addition of "extra" tanks will cause your pump to run longer during fill, and allow much more water to be drawn between pump starts. Second, Since the tanks do not require continual air additions, they have far fewer parts to malfunction - and do not become "waterlogged" unless the bladder breaks/leaks. Additionally they can exhaust almost all the water held in the tank without undue pressure drop - allowing for much smaller tanks serving the same function. IE: Cause of the surprising ratings in capacity VS non-bladder tanks.
