UHMW Plastic
UHMW Plastic
UHMW Plastic
Barbara Gill, Remlik VA
>I am in the market for a sheet of UHMW plastic to use on our molder/planer we use in the sawmill. We have a Bridgewood machine which has from the very beginning been a major PITA to keep the bed rollers adjusted. Today we realized if we lowered the rollers and put a sheet of UHMW plastic over them it would probably make milling flooring much easier.
Can anyone suggest a good place on the East Coast to get a sheet around .5" x 36" x 36"?
Re: UHMW Plastic
Re: UHMW Plastic
Howard
>try McMaster Carr www.mcmaster.com P/N 8752k135
Howard
Re: UHMW Plastic
Re: UHMW Plastic
Virgil Johnson
>McMaster Carr tends to be a bit more expensive than most local plastic suppliers. I would check your local yellow pages for plastic suppliers. Most plastic suppliers can cut to size. Google "GE Polymershapes" they have a branch in Richmond VA. I've bought lots of plastic from them.
Re: UHMW Plastic
Wow
>Wow, Howard, what a site. Thanks so much.
Re: UHMW Plastic
Re: UHMW Plastic
>Thanks Virgil. I will check them out as we are only 60 miles from Richmond.
Re: UHMW Plastic
Re: UHMW Plastic *LINK*
Ron in Drums PA
>I don't know if these sizes will work for you, I've used this company and have been happy with their services
FYI - Cutting boards are UHMW
UHMW
Re: UHMW Plastic
If I might make a suggestion.....
Dominic Greco in Richboro PA
>Barbara,
I'm not sure how much a slab of UHMW cost. But maybe here is a more economical solution.
I'm wondering if a sheet of plywood with pieces of UHMW fitted into grooves would work just as well. I bet that 3/4" x 3/4" strips of UHMV would be much cheaper than a big slab.
All you need to do is mill the UHMW to the same width and thickness, mill daddos, in 3/4" plywood, and install the strips. Just be sure to make the UHMW strips sit a hair proud of the surface of the plywood. Space them about 1" apart. On the reverse side of the plywood, adhere some strips of sandpaper so it will grip.
This would have a couple benefits. Number one weight. Number two, once it's in place, the plywood will stay. The UHMW will want to move (it's slick as hell remember?) unless you fasten it in place. Number three, when the strips wear, replace them!
How's that sound?
BTW while I use them often McMaster Carr is usually the most expensive place to buy things like this. They're attraction is their ability to have all this stuff under "one roof" , and they're able to deliver to your doorstep within a couple days. At my old job, we only used to use them when time was really critical. You could probably find a local vendor of this stuff by checking out Superpages.com (aka: Bigyellow.com)
See ya around,
Dominic
Re: UHMW Plastic
Jim Dillon
>Barbara,
US Plastic Corp. has a good selection as well. UHMWPE will not be cheap, no matter your source. Here is a link that might be helpful. I've had good service from them and their catalog is worth having on hand. Good luck.
Jim
US Plastic Corp.
Re: UHMW Plastic
Re: If I might make a suggestion.....
>Thanks for the suggestion Dom. I will discuss it with the guy that I do the flooring with. We had planned to screw the sheet to the bed of the planer (counter sink screws).
Re: UHMW Plastic
Re: UHMW Plastic
>Thanks Jim, they had the lowest price.
Re: UHMW Plastic
Thanks Ron.
Re: UHMW Plastic
Re: eBay has plenty.
>Thanks Tom; they didn't have the right thickness.
Re: UHMW Plastic
Re: UHMW Plastic
Bill Sams
>One more option. A place on I-95 south, exit 69 southside of Richmond called Peidmont Plastics. I just purchased 32 sheets of Lexan 4x8 and there were cheaper than any place I had researched before. If interested I can look up their number for you. I found them through a mid-atlantic supplier book, but they might be in the Richmond yellow pages.
Good luck
Re: UHMW Plastic
Re: UHMW Plastic
>Barbara,
Try Plywood and Plastics, they are over near the Diamond. I think they have changed their name, but they have been there a long time (30+yrs). Give them a call, If you can't find them let me know and I will hunt them down.
If they have a sheet of what you want, you can pick it up Thursday and combine it with a Turning Club meeting. Good excuse to make the trip.
Have you thought about using Plastic laminate on a sheet of plywood? I bet it would work and be cheaper. Might have to laminate both sides "for balance". I bet if you shop around you might be able to find some "Ugly" laminate cheap. Also, you can buy melamine coated plywood (borgs have it) and it works well for stuff like this. Very slick, but the coating is thin. Don�t know how long it would wear, but you could get three 32 by 48 pieces out of a 4 x 8 sheet and it would be a lot cheaper than the UHMW stuff. If you got that way, it won�t work exposed to the weather and you should seal the edges.
Re: UHMW Plastic
Re: UHMW Plastic
>Thanks Barry and Bill. I had forgotten about Plywood and Plastics and the outfit near Petersburg didn't come up on my search either.
Barry, the only problem with the meeting is I really don't like to drive at night unless I have too. My eyes are not what they used to be. :-)
