Music Box etc. Picture 1
Jim Dillon
>Hi folks,
Here are three projects I completed last Xmas that I thought you might enjoy. I grouped them together to save posting space, but I have others that show more details if needed.
On the left is a walnut and cherry music box with ebony handle, feet and miter keys. Finish was 2 coats orange shellac (1#) inside and outside followed by 3 coats of Tried and True on the outside only. This was followed by several coats of wax. Corner joinery was a basic miter with reinforcing keys. Box hinges were Brusso. Music movement is a 50-note Sankyo from Better Music Boxes. The walnut came from inside an old horse barn and may be many, many years old. I wanted to have the miter keys equally spaced, but, alas, I forgot to allow for the width of the tablesaw blade when cutting the lid off; so that is why the two top miter keys are slightly closer together. Oh well. Credit for ideas: Doug Stowe's book on box making.
On the right is a locust and spalted sycamore jewerly box. Two coats of pale blond shellac (1#) followed by 3 coats of Tried and True on the outside only. This was followed by several coats of lavender-smelling wax. Corner joinery were loose tenons. "Hinges" were 1/8 inch brass rod. Credit: Dave Freedman, American Woodworker, October, 1997.
On the bottom is a stacking puzzel. The puzzel frame is jatoba with ebony miter keys. The puzzel pieces are made from jatoba, maple, vertical-grain douglas fir, mahagony, and spanish cedar. Finish is one coat of pale blond shellac, followed by 3 coats of Tried and True and then several coats of wax. I was totally surprised at how long it took me to make each puzzel and how tedious it was to keep track of the individual pieces because they all look so much alike and are actually mirror-images which made it even more confusing. Credit: Allan Boardman's version of Nobukujuki Yashingahara's "Neverending Puzzel", American Woodworker, October, 1998.
What I learnt from these projects is that just because a project is small doesn't mean it will be easier than a bigger project. In fact, because one can pick up each completed piece and closely inspect it, makes it even more critical to do a good job. But there was a lot less sanding (at least for the music and jewerly box) than with a bigger project - for which I am very grateful! However the glue-up and sanding of the puzzel pieces was tedious and seemed to go on forever.
Jim
Re: Music Box etc. Picture 1
Music Box etc. Picture 2
Jim Dillon
>Here the music and jewerly box are opened showing the inside details. The music box has a glass cover that is removable if it breaks or access to the movement is necessary. By-the-way, it sounds superb! The movement base is solid brass and must weigh close to a pound. The jewerly box has a small tray made from mahogany with "felt" from Woodcraft; the tray is removable. One of the puzzels is disassembled. There are 11 solutions to the puzzel, one of which is shown. Another is a cube. The puzzel is actually quite hard to solve, at least for me 8-). Although there are only 8 pieces, it isn't that easy to get them all to fit together
Music Box etc. Picture 3
Jim Dillon
>I thought you would be interested in the jig that is used to make the puzzel pieces. The only starting material for the puzzel is a piece of 1 inch x 1 inch x 24 inch wood. There is a "hold-down" to hold-down the small piece so it won't go flying when cut; the hold-down is on a pivot. The adjusting screw just to the right of the hold-down sets the exact width of the cut piece.
