Highjack?, but on topic. Garage wall panel saw.
Craig Daymon
>I'm in a townhouse now and getting a 4x8 sheet downstairs is impossible.
I've been thinking, and this may be something for you to consider, of creating a panel cutting system using the exposed stud wall in my garage. The idea still needs some work, but essentially a tray that would hold the sheets and T-square style cutting guide to use with my Skil Saw.
Of course, I don't want to keep slicing into my studs, so it might have to lift away from the wall about 1/4", unless I restrict myself to vertical cutting motions, which could easily run between studs. I also might want it to be able to clamp the boards somehow, maybe using T-track attached to the sides of studs.
Anyway, I think this idea might handle my panel cutting needs. Is there a chance anyone has done this already?
-Craig
