Jointing
Robert Egbert
>I have an 8" jointer and a bunch of 10" & 12" 5/4 red oak boards. Any one have a system for jointing beyond the 8" capacity. Rip and glue was my first thought
Jointing
Robert Egbert
Re: Jointing
>Good Evening Robert,
I run into that problem almost every time I use my 6" jointer. I've gotten pretty good at ripping, jointing, and gluing. I don't have much remorse because I am careful about matching grains and using cawls when I glue up. Any slight difference in level can easily be handled on my 12" planer.
George
Re: Jointing
Robert R Clough - Thorncraft
>Robert I remember reading, but for the life of me I can't re,e,ber where, that one can joint wider boards than capacity. Hopefully someone here can help.
Re: Jointing
Robert Egbert
>I seem to rember hearing that also
Thanks all
Re: Jointing
Virgil Johnson
>Using hot melt glue fasten (3) 3/4 x 3/4 stips of pine lengthwise to one side of the wide board. Use a hand plane and winding sticks to level a plane created by the pine strips. When you have a flat plane established run the board through your planer with the strips down. When the tops surface cleans up remove the strips and plane to thickness. Or skip fastening the strips on and plane one side flat with a hand plane. I used the strip method to surface some 24" wide cherry with good results.
Planer bed - search for earlier posts /nm
Ells in Boulder
Try this
Denis Ch�nard, Orl�ans, Ont.
>Warning: the procedure involves removing the jointer guard, so if you're not comfortable with that, don't try it.
The procedure is akin to making 8" wide rabbets. Set your jointer fence for maximum width of cut, then run your boards through. This will leave an un-jointed strip on your board, but that's OK. Run the board on the jointer until the cut section on your board is flat and straight.
Once this is done, use a hand plane or handheld power planer and bring the un-jointed part of your board flush with the jointed section. Once this is done you can run the board through the planer to bring the other side parallel to the first one. At the end, flip the board over and run the initial face through the planer to clean it. Works great.
DC
Re: Jointing
Jim Dillon
>Robert,
Normally I rip, joint, and glue. But then I built the planer sled based on an article in FWW and it really does work as advertised. Several WoodCentral folk, like Ells, have built one and seemed pleased with its operation. Do a search for "planer sled" within the past year and you will find it mentioned plus other hints on how to joint wide boards with a jointer alone and/or using handtools. Good luck.
Jim
same here, except the hand planing...
John in New Mexico
>Once I have the two "overlapping" rabbets on one side, I plane the other with the surface planer, once it is flat, flip the board and plane the jointed face.
I don't do much over 12" 'cause that's the width of my planer, but also because you need a little overlap in width when jointing the first side - so an 8" jointer can do up to about 12" or a little over.
Never even tried a planer sled, but they're pretty popular too.
John
Re: Jointing
arw01
>Robert:
If you own a scrub plane, getting the wide board to sit reasonably flat should take only a few minutes. You don't need it to be perfect, so enough to stop it from rocking obviously.
Once you have it stabilized from corner and side pressure, run the "flattened" side through the surface planer with LIGHT passes.
It is a good idea to only do a bit of the machining, then let the wood acclimate some more incase it wants to move with the new found removal of wood.
It's a shame to rip those wide boards down ala Norm's style, rather than take an extra couple of hours and do the job correctly.
Alan
Make that "Planer sled"
Ells in Boulder
Re: Jointing *LINK*
charleychip
>Here's a couple of diagrams.
American Woodworker
Re: Jointing *LINK*
charleychip
>Hope these help.
Woodsmith
