battery replacement
battery replacement
battery replacement
Ray SW Ohio
>Is it possible to replace the batteries in a cordless drill yourself? If so, where can you find the batteries? TIA, Ray
Re: battery replacement
Yes *LINK*
Hoa Dinh in Alameda
>Don't be taken aback by the prices. They seem high but the quality is top.
-- Hoa
Battery Rebuilders Website
Re: Yes
Ray SW Ohio
>To replace the batteries is more than I paid for the drill. Might be cheaper to replace the drill. Thanks for the reply. I was hoping to buy the batteries components myself and put them in.
Not a good idea.
Jason Roehl in Mulberry, IN
>There are special tools/processes used in rebuilding battery packs. Trying to solder the tabs yourself would be highly detrimental to the battery cells due to the heat you would be putting into the cell. I believe the rebuilders use some sort of spot weld that doesn't heat up the cell very much if at all.
When it comes to cordless tools, I'm convinced that it is a "you get what you pay for" game. I have friends that go through cheap drills like TP. I just got about 6 years of abuse out of my P-C (used on the job, but not daily).
Jason
Re: battery replacement *LINK*
Jay L in Glenview
>I bought these and rebuilt one. It was an interesting project and it worked just fine, but I probably wouldn't do it again. You can purchase them rebuilt or send yours in to be rebuilt for the same price you are going to spend for the batteries and shipping. You have to buy huge quantities to get them cheap enough to make it worthwhile.
Just my .02
Jay
Amondo Tech
Re: Not a good idea.
Ray SW Ohio
>Probably right. Had the drill for almost 5 years, it served me well.
Larry Clinton At Frankfort (Central)., Indiana
>I have soldered and welded tinned strips to batteries before at the factory I retired from. However I had top grade equipment and heat sinks on the strips. I would not recommend this to a novice at electronic assembly. I also agree with Jason that the Elcheapo units are not the way to go. I gave away an Industrial Craftsman and 2 dead batteries (looked like a Porter Cable) drill with charger I had for about 4 years. It had done everything I asked until the batteries went south - but it cost over $125. I then bought a cheap unit thinking it would suffice and I could toss it in a year. Didn't work well, had little power or battery life. I think I tossed it in less than 6 months. I then acquired a DeWalt & it lasted about 5 years (still works but the batteries are about gone and drill arcs pretty bad). I just bit the bullet and bought a Ridgid yesterday. I purchased the 12 Volt drill and the 14.4 Volt Impact driver. I am registering them immediately so I will have the "extended service agreement". I checked and there is a service center for the tools about $0 mile away at Indianapolis. Hopefully with this guarantee of free battery replacement (and free tool repair) for life, it should be my last cordless drill purchase. I lucked out as HD at Lafayette, IN had not taken the "instant rebate" on power tool sign down. This offer was $35 off $150 to $399 & $75 off $400 to $600 (or something like that). I purchased a total of $410 and they took $75 off the tab. I registered this in my sons name as he will use it more than I. At my age, Lifetime warranties are not what they used to be. :~).
Re: should read " service center 40 mile away"
