Dulling Satin Poly??
>I use various finishes for my projects but when I use poly I like to use Minwax wipe-on satin poly. But sometimes it gives me more gloss than I want. Is there a good additive I can use with that wip-on poly to get a little less sheen?
I wide open to suggestions!
Thanks
Tom
Re: Dulling Satin Poly??
rub it out
Dan Donaldson
>Use some fine steel wool and wax and rub it out.
Re: rub it out
Mark Kauder, Phenix City, AL
>I agree with Dan. Unless you want to put on another coat, then the best way is to hit is with a fine abrasive that will knock it down to the level you want.
Mark
Re: rub it out
Ken Oakley-Sunny St. Cloud, Fla.
>I use 0000 steel wool and no wax. Then rub it down with an old tee shirt or like material. Wax puts a gloss back on it.
