Trees--What happens after a heavy frost?
Gary Evans Tallassee, TN
>Hi all,
When the 20 degree temps rolled through here last week, the poplars and ashes already had their leaves well out. Now I'm looking at lots of shriveled brown leaves.
So what happens now? Will the trees leaf out again from unused buds or what? It's been years since we've had temps this cold this late in the spring, so I don't know what to expect. Guess I should have paid more attention last time this happened, huh?
Thanks,
Gary
Re: Trees--What happens after a heavy frost?
Yes, they will leaf out again.
Don Henthorn
>Won't take too long.
Re: Yes, they will leaf out again.
Tom Dunlap in Atlanta
>Since it happened early in the season the trees haven't spent all of their savings account of stored starches to buy this seasons food factories...leaves. If the trees aren't stressed they should have enough extra starch to reset three sets of leaves. After that...even the best energy savers, white oaks, are going to have a tough go of it.
If any of the trees had flower buds set they will probably be gone for the year. Trees only make one set of flower buds per year. Unless you have a desirable flowering or fruit tree that's good news. Fewer 'helicopters' from the maples and ashes or acorns the better off.
Tom...the tree guy :)
Beyond what happens to the leaves
Keith Newton
>If you are one of those who harvest their own wood, and read the rings for whatever history that is recorded therein, this may be a good year for a false, or frost ring.
I am not the expert, but I have a good friend who is a dendrochronologist, whom I have had a few discussions with about this, and briefly here is what happens.
For example, In ring-porous woods like Oak, the Early-wood, or first cells to grow in spring are the open porous part. Then later through the Summer,
thicker more dense cells develop. I don't know about this year, but sometimes it will happen later than this, but after the thicker late-wood cells of summer start, if there is a freeze, there will be a false ring.
This may look similar to a normal Spring, followed by a drought through the Summer. However since we are now well established into recorded weather-history, it should be easy whenever, in the future, that you cut or receive wood, and you notice the rings, that you may see evidence for this year of a line embedded in the rings showing a disruption in the development of cells for this year.
I will send my friend an email to ask what his prediction for this year's ring will be, and get back if anyone wants to know more. Personally I love to read the history of a tree in its rings. If you just buy lumber from the store, you don't know what you are missing.
Ron in Drums PA
>We have a few apples trees. As you may know, apples flower every other year.
One year, when the flowers buds where about to open, we had a frost. It killed all the buds and most of the leaves. I was a bit worried and all I could do is just wait and watch.
Within a few weeks the leaves started growing again and the tree flowered the following year.
Tony - Memphis
>We took a heavy hit down here too. A lot of the new leaves (even on my hollies) were killed. We are going to have an early fall and a second spring! Lost most of our azalea blooms. At least we aren't dry yet (like last year).
Hope your/our trees recover.
Tony
John McGaw
>Unless the trees were already stressed they should drop the dead leaves and bud again. The new set of leaves might not be _quite_ as full as the first but a healthy tree should manage just fine. The same is true for many perennial plants that you have in your yard -- at worst you may lose blooms from plants like irises that already had their flower buds well along. Plants like day lilies (a.k.a. ditch lilies hereabouts) are essentially about as killable as dandelions and should have no problems.
Personally I'm not too worried about my trees since my small property has more than it needs and there is always a use for more firewood. It would be nice if, for once, any trees that decide to die would do so in an evenly-distributed manner. Of more concern are some expensive ferns in the back yard that got whacked pretty well after suffering from the drought last year.
Al Stokka - Cambrige, Iowa
Don,
I don't know what sort of strange apple variety you have in Pennsylvania, but apples in Iowa bloom (and set fruit) every year barring a killing frost. Some varieties will bear a heavier crop every other year, but produce flowers every year.
Al
Sgian Dubh
>Gary, trees are a lot smarter than perhaps some people give them credit. They have inbuilt strategies to cope with unusual or difficult weather from season to season.
Leaf bursting is known as flushing. In temperate climates the first flush occurs at the beginning of the season when daylight length and rising temperatures cause chemical responses in the tree leading to the flush, which brings with it rising sap and photosynthetic activity.
Should this fail due to later inclement conditions trees put out a second flush. Trees put out a second flush anyway regardless of difficult conditions.
Some tree species, oaks being particularly notable, put out up to four or five flushes a year. The fragile blades that are the leaves of angiospemae are damaged in many ways-- hail, frost, insects, birds, animals, and just pure old age for instance.
The answer to these depredations are several flushes a year. On white oaks look out for at least three flushes. An early season first flush, a second flush four to six weeks later, and a Lammas flush in early August. The Lammas flush is often characterised by red hues in the new leaves. There may be yet another flush or two in some white oaks in mid-September and even October.
The Lammas and autumn flush(es) produce young vigorous leaves able to photosynthesise frenetically in the waning daylight in order to produce a rush of starch for the necessary winter storage.
I could say more about the ability of trees to cope with both favourable and difficult conditions, but unfortunately this is all I have time for. Try though looking up Lammas on the internet to see the significance of the name Lammas flush.
The above information is very generalised, and things may work somewhat differently in your area. It depends on the typical climate the trees are living in, and the species variation to start with. Slainte.
Those are BAPPLES
>Apples that flower every two years are Bi-Annual Apples, or BAPPLES for short. ;)
Seriously.......
I guess I just used "Bi-Annual" incorrectly. What word means "every two years"? Bi-annual means twice in one year, right?
But Bicennential means every 200 years.
So what word means "every two years"? Would it be bi-antenial?
No, that would be an ant or other insect with two antenna ;)
English is hard, think I'll stil to BINARY ;)
Happy Woodworking!
Growth increments/flowering
>In equatorial trees there is no annual growth ring because the trees tend to grow at a steady pace the whole year. A better term is growth increment. This account for some of the years when conditions are such that a tree will have two growth increments as Kieth Newton wrote.
I'm curious about the flushes that Richard talks about. I'm going to be hitting Google.
My understanding of woody plant growth is that all of the current year's growth is included in the annual, terminal bud. The plant just extends that during the season. I have heard of some special conditions where the spring is so good for growing that the tree will make it's annual extension then get faked into thinking that it's fall because of an environmental stress. The buds then pop again and grow.
Most of the plant triggers are based on day length so that is one that can't be altered.
Most trees will grow vegetativly one year and fruit heavier in alternate years. If the tree is stressed it won't flower or if it's severly stressed it will flower VERY heavy in a last ditch attempt to replicate itself. Flowering takes a lot of energy and most plants/animals don't have enough energy stored to be constantly pregnant.
The years that were conducive to acorn crops got to be frustrating. Some people who have a yard full of oaks get tired of having the patter of acorns on the roof. Not as romantic as rain and the acorns clog the gutters. Too often I would spend time convincing people to not cut down the oaks. Most times I was successful.
Tom
Ron in Drums PA
>From what I'm told, you can trim apple trees in a way that will force the tree to bear fruit each year. It's not hard to do, just time consuming and I wish I had the time.
What I should have said that my apple trees have a heavy crop every other year and a very sparse crop in between. It flowers in the sparse years but hardly worth even looking at.
Next time I will wait until the coffee kicks in before I post a message.
Re: Those are BAPPLES
Jim in Fenton, MI
>Semi-annual would be twice a year. Biannual is two annuals or every other year. Bicentennial is two centennials or every 200 years...
Dave Bair, Eaton Rapids, MI
>Not to worry. I've had small cherry trees completely stripped of their leaves at mid-summer by japanese beetles. They all were able to set new leaves that same summer. These leaves got frost-blasted in an early frost later. But those same trees are now doing fine 5 years later.
Biannual vs Biennial
>If I understand the Meridian Webster Dictionary:
Biannual is twice in one year. http://m-w.com/dictionary/biannual+
Biennial is once every two years. http://m-w.com/dictionary/biennial+
I dunno... I was just stretching for a reason to say: BAPPLES
Happy Woodworking!
All of us pilots…
Rod Peterson -- Ormond Beach
>…can easily remember that our Biennial Flight Review (BFR) is due every two years.
Rod
Thanks for the info, guys.
>I'm not terribly worried about the health of the trees, just wondered about the mechanism that protects them when these conditions occur.
Wasn't aware at all about the "flushing" process. I'll have to take a look at that later.
I did know that not all leaf buds develop into leaves in a particular season, and thought perhaps that might be a clue as to what will happen as spring proceeds.
Thanks all,
Gary
Re: Bapples can be fixed!
Bill Turpin in WNC mountains
>Next year's buds form at the base of this year's bud. If there is an apple hanging on this year's bud, then next years bud (in bapples) goes dormant. When the apples are the size of dimes, knock or pick half of them off! On small trees use this opportunity to remove the small, shriveled, bug bitten, diseased, etc. fruit. LEAVE ONLY ONE FRUIT PER BUD CLUSTER. You will get bigger, sweeter fruit in a usually larger volume. It will certainly taste better. This thinning will also lessen the fungus/mold caused by non-drying fruit that touches another apple.
On bigger trees, take a long pole(cane fishing pole)and attach two feet of old garden hose to the upper tip with a hose clamp. Beat the heck out of the fruit clusters. The tree will look terrible for a few days before it starts looking better. After several years of this treatment your trees will become more apple and less bapple. Professional growers use hormonal sprays to accomplish this and they remove 75% of the dimes in early June.
Your choice: Lots of small, sour apples every other year or a medium crop of better, sweeter, prettier apples.
Bill who lives in an apple orchard
in WNC mountains. 100% lost crop due
to Easter freeze
90% of Peach crop lost also......
Basil
Ernie Miller
>I have a peach tree in the yard that got hit hard 5 nights of 20� or lower the flowers had bloomed and set 2 weeks befor the cold. it dosent appear that any have droped is the crop lost or might they be hanging tight? in another strange behavier I saw several new flowers opening up yesterday so I might get a few peaches no matter what. The garden was looking so nice and now it has been knocked back real hard. the tomatos that didn't get set outside only placed in 6" post are almost 2' tall and some will be planted outside this week I even have flowers on them.
