Help! I need 1/16" and 1/8" stock...
Steve Yakoban
>This isn't exactly a cabinetmaker's type of question...
Nevertheless I'm in need of some 1/16" and 1/8" "shim stock" to level some subflooring for an intricate tile/hardwood project. I have to shim more joists than plane, so the shim stock is a necessity. I only have a table saw w/a fence that has to be hand squared each time. I've run some 2x4's through there to make some shims, but it's a big PAIN.
Is there anything already on the market in these thicknesses 1-1/2" wide or more? (Doug Fir, Pine, etc.) Is there a better way to make these shims?
All suggestions are appreciated!
Re: Help! I need 1/16" and 1/8" stock...
Lee Gordon
Lee Gordon
>I'm not sure what you can do about your 1/16" shims, but masonite is available in 1/8" thickness. You'll still have to use your table saw to rip strips of it but that job would probably not be as fussy as ripping 2x4s to precise thickness.
Curly Smith
>If plywood will work then you can get as small as 1/32" easily from--
scroll saw suppliers, like this one:
Plywood
hobby lobby (and presumably other craft stores):
Wood
Model builders supply, sorry, no link handy...
Steve Yakoban
>Thanks. I see that some of the model/craft shops sell basswood. I know it's soft, but my questions are:
Will it compress easily (under a subfloor)? Is it like balsa?
Thanks!
Jim Dillon
>Steve,
Are you aware that the local borgs sell packages of "shim" stock? Granted that it tapers from, say, 1/16-1/8 inch to roughly 1/4 inch - but it might be useful for your application. I've actually used these pre-packaged shims for a lot of applications, including stirring paint 8-). Just a thought.
Jim
Andy Lincoln,In Dearborn MI
>Steve,
Go down to a local cabinet shop/supplier or even a borg and buy plastic laminate(Formica/Wilsonart/etc) its 1/16" thick and you can also buy 1/32" edgebanding material if you need even more precision.
You could also go to the local borg find the sample rack for all the laminate chips and maybe get enough to use as the shims for your subfloor job,they are all cut approx 1 1/2"x 2 " I think.
Andy
Curly Smith
>Basswood is relatively soft (although it is a hardwood) but it's used in models and for carving because it's straight grained, not because it's soft.
According to the Wood Handbook (download from here as desired: Wood Handbook )
Basswood has roughly the same compressive strength properties as Eastern White Pine.
Compressive strengths (kPa): Parallel to Grain, Perpendicular to Grain
Basswood 32600, 2600
Pine 33100, 3000
Steve Yakoban
>Thanks. That's the kind of numerical stuff me likes...
NickB
>Am I correct in assuming you're trying to get the subfloor so level that you won't have any lipping problems?
I would think that single thickness material will prove to be a bit frustrating. Try buying a bundle or two of "starter shingles" from your local lumberyard/roofing supplies place, rip strips the width you need, and have at it (in CA I used to be able to easily find big bundles of shims (door hanging, lots of doors), but couldn't find anything other than the little, plastic-wrapped packages for DIYers in MA). By sliding two shims in opposite orientation, you get a flat surface that you can adjust to make the thickness you want.
Hope this helps,
Nick
wilbur
>Can you do this with thin wedges? I've usually addressed this type of issue by tapping a wedge in until I get the level I want. That way you don't have to worry if the offset is an in-between distance.
Roger Marks
>Hi Jim, Yours is the correct and perfect solution to this problem.
Years ago, we (commercial carpenters) used wood shingles for this and other shimming needs. It would seem the little bundles of shims you refer to would be less expensive than using actual wood shingles.
Roger Marks
Thanks.
Steve Yakoban
>Thanks guys! The ideas are appreciated!
