Re: Cabinet Doors with Glass Panel
Bill Hylton
>Howard,
Bill Hylton's Frame & Panel Magic, a book you should be able to buy through amazon and other on-line booksellers, has a chapter on making glazed doors. It's got info on using sash bits and specialized cabinet-door bits, including the recoverable-bead bits and Marc Sommerfeld's bits that make cuts for glazed doors with a rubber retainer. It explains how to alter a standard cope-and-stick set to make frames with a rabbet instead of a groove. And it covers the Freud and CMT/Lonnie Bird divided lite bits. Also shows how to rout loose-tenon joinery to reinforce cope-and-stick constructions.
Talks too about profile proportions and appearance. A key difference between recoverable bead bits and divided lite door bits is the profile scale and finished appearance of glazed assemblies made with them. What looks okay for a single-pane door doesn't always look right in a divided-lite door.
Book's worth its weight in screwed-up door parts and bits you wish you hadn't bought. (Even if I do say so myself!)
Bill
