Thinking about a bandsaw
>I've suddenly got a little extra money to spend on tools. Coincidentally, a local tool store is offering the Delta 28-276 bandsaw for $379, which appears to be about a $130 savings over Amazon.
My existing bandsaw is a Power King 12" saw, which runs well; but, since it's a dinosaur brand, if it ever breaks, I'm stuck, and I use a bandsaw a lot, so I'm thinking about this purchase.
How do folks feel about the Delta? I know it traditionally was a very good saw, but I also know that some makers have let quality slip in recent years.
Re: Thinking about a bandsaw
Details *LINK*
>The link below points to the saw in question.
Delta's description.
>Delta service isn't what it used to be. The quality is reasonable.
Are you sure this is the bandsaw that you want? I don't think that this model can take a riser block if you ever decide to go that way.
Bart Goldberg
It does take a riser -ook at description
Bart Goldberg
Re: I sit corrected!
size matters
Tom Sontag - St. Louis
>My impression is that you are taking a baby step up the BS ladder. I am not quite sure what the Delta offers you that the Power King does not (other than access to spare parts).
Especially if you resaw, bigger is way better. I've seen 36" old iron bandsaws go on eBay for less than $400 (not counting shipping, but it seems like you could wait for a close opportunity). Yes, you may need to replace the motor or apply TLC in other ways, but it will change your ww'g in a major way.
Okay, you don't need a 36" BS and who has room anyway? But why not husband those dollars and keep an eye out for a meaningful upgrade via the used market? Old iron is your best value IMO.
Thanks, folks
>I fantasize about a 36" bandsaw, but my shop is 11 feet square (into which I've shoehorned the bandsaw, a 10" contractor's saw, a workbench, four mechanic's rollaways and three top chests, a small drill press soon to be replaced by a larger one [on one of the rollaways], and more small tools than I'd like to admit to), so that fantasy is contingent on the larger-shop fantasy.
Still, there's a lot of things in which I'm interested with that limited money, so I might be better off holding back...although I have until the end of the month to decide.
Thanks for the advice.
Re: Thanks, folks
wilbur
>What's the ceiling height in your shop? And what do you plan to do with a bigger bandsaw?
Knowing these two factors would help in making a decision.
Jesse in New Mexico
>Hey Bill,
I have an older version of that saw and it has performed well. Unless you plan to resaw large boards, it will do just about anything. I have sawn curves in 12/4 stock with mine. The price is a steal.
If you are thinking about a riser (and I'm not sure the riser would do much good on a 3/4 hp model anyhow), get it in the beginning as it will change the blade length that the saw takes and you don't want to buy blades that will be obsolete.
Get Louis Ittura's catalog. He has lots of suggestions for tricking out the deltas.
>Bill, I have a Delta saw and I have a love/hate relationship with it. Iturra said I was lucky to get on the "last" American made ones, before they went to China or Taiwan. Now I understand they have brought some of them back and are making them here. I doubt they are the ones with the really good price point. Also, I don�t know where yours is made or if it really matters.
I have added a riser block and a Carter quick release on the blade, and band rollers and dust collection and...... If I had realized how much I was going to spend beefing it up I would have bought a bigger saw to start with. I am now considering adding a bigger motor. Give it some thought.
Re: Thanks, folks
>Ceiling is around nine feet - that's not an issue so much as the square footage.
It's not so much the larger saw as the saw for which I can get spare parts that attracts me. Well, that and the fact that it's got a quick release for the tension, as I always release the tension when I'm done.
Still, my list of wants is long enough that I'll probably pass. I don't have that kind of extra money often.
Lee Schierer, McKean, PA
>I have a Delta that is a similar model. I had to do some rework of the guide system under the table to get it to work properly. They had some interference between parts that they solved by putting in a screw that was too long that bottomed out in the tapped hole so it left the assembly loose. Fortunately I work in a machine shop where I could get the work done for free using machines here at work after hours. Other than that I've enjoyed having the saw. I've resawed 6" soft maple and red oak on mine with little problem, once I got the belt properly tightened.
Lee
