Real small breadboard ends...
Scott in Douglassville
>Hi, all, long time no post...
Ok, after a long respite from woodworking, I have a task: As part of a new interest in large format photography, I have a request to build a lensboard for a refurbished 8x10 camera. An example of this here beast is:
Photo Sharing and Video Hosting at Photobucket
The size of this board is gonna be 5-3/4" square. Traditionally, these boards are made with tongue-and-groove breadboard ends. Also, they're traditionally about 6" square, so I'm guessing that the breadboard ends aren't glued along their full lengths. Here's the tricky part - the lens board is about 1/4" thick.
So, how to go about making one? The guy wants one close to the original - no plywood or one-piece boards. I can almost see making a thin little tongue, but can't imagine milling it without breaking it.
Suggestions?
Thanks,
Scott, still in Douglassville
Re: Real small breadboard ends...
>Scott I made 6 for my old Kodak 8x10 and have made smaller ones for my 4x5. I use a slot cutter for the router cut a dado in the body of the lensboard and then cut a full length tenon on the breadboard ends using the table saw. It's handy to have the speed reducer for the slot cutter. They burn the wood really easily. I only glued them in the middle for about 1/2" or so. If you use mahagony there will be less movement and fewer problems.
I've also made excellent lens boards out of black 1/4" plexiglass. It's much quicker and easier although not very traditional.
>Hi, John -
How thick did you make your three piece boards? I'm thinking I'll try to convince this guy that 3/8" would be a better thickness...
What kind of 4x5 ya got?
Scott
A.J. Hamler
Would this work?
A.J. Hamler
>If it were me, I'd make it out of 1/2" stock, which would be easier, and then plane or drumsand it down to 1/4". Just a thought.
A.J.
Re: Would this work?
>I've thought about that, AJ, but would still need to make the tongue appropriately thin, and would be worried about a ~6x6 piece going through my planer. Not sure if that joint, only glued in the center, would withstand the planer, either, come to think of it...
>Scott I made mine exactly like the Kodak boards and as I remember they were about 1/4". I don't have any film cameras anymore. I had a Kodak #2D 8x10 and a Zone VI Wista 4x5. I still have a bunch of 4x5 film holders if you need any. Also have a polaroid back or two. I just sold all the lenses. Took a huge loss. Everything film has devalued so much. I shoot only digital now. I have a canon digital rebel but I'm trying to up grade to a Nikon D80. At work I have everything Nikon from D100's to D2's and a 4x5 Cambo, a couple of 6x7's that we don't use anymore.
Jesse in New Mexico
>Wow, that's a challenge!
I think I would cut a slot in both the main board and the bread board, then mill some tenon/spline. You could route a small groove toward the ends of the spline, then glue the center and peg the ends without glue.
I would go for a 1/8 spline with 1/16 left for each cheek.
Hope this thing won't have much stress on it...
Rob Stokes in North Vancouver
>If you have to make many, make one really long one and cross cut it into pieces.
As for the breadboard ends, mahogany is very stable and you'll not get a lot of expansion/contraction. Even so, I'd glue an inch (both sides of the tenon) in the middle and let the outer edges float. No need for pins - it's not going to live a hard life.
Good luck!
Rob
Wow, that brings...
Jim Dillon
>... back memories. I almost bought a Zone VI 4x5 back in the mid '70s, but it was priced too high for my student budget. But I do have the Zone VI newsletters from the mid-70s (does that count? 8-)). Instead, I bought a very used Alpa that I cut my teeth on. Still works too, sorta. I then moved on to Nikon cameras thinking that would improve my photography. It didn't! Then there was the portfolio of (10?) Ansel Adams originals for $600 that got away. Saw the portfolio on Antiques Roadshow recently going for $35,000! Such is life. Good luck with your D80.
Jim (proud owner of a D70s and still learning)
Lee Gordon
Lee Gordon
>Could you use biscuits?
