Strange stain problem
Eddie Pacheco, San Jose, Ca.
>A friend asked me to stain all of the stain grade pine windows and trim on his home. These are new Anderson windows that he had installed along with pine trim. I did the usual process of sanding to 220 and conditioning the wood with thinned out (1:1 ratio) Zinsser Seal Coat.
All of the windows and wood trim took the staim well with no blotching except for the sliding glass door. When I applied the stain a large section of one stile does not absorb the stain. I did 2 applications of stain and still it wipes off in this area. I resanded the whole stile, cleaned it with mineral spirits, then alcohol, and applied a new coat of conditioner. Waited a day and same results.
I notice that the pine is about a 1/8" thick veneer over some other wood. Could the adhesive used to bond the veneer have bled through or gotten adsorbed by this section of pine? The staionary portion of the slider took the stain well and the rest of the slider portion is fine.
This area is around the door handle and stretches for about 9-10" either way from the door handle. It's a well defined zone of inpenetrable wood. I suspected silicone or oil so I did a real wet clean up with alcohol as a final step before conditioner, but it didn't help. The area didn't grow with the 2nd sanding so the contamination is staying put.
Any ideas?
Re: Strange stain problem
Paul Dwight
>Sure sounds like the surface was contaminated with something during the manufacturing process that sealed the wood. Probably glue, I would guess. Since sanding didn't open up the pores enough for the stain to penetrate, I think you'll have to use a different coloring technique for this area. Put the color in the finish, instead -- make up some toner out of SealCoat and Transtints, and apply in thin layers to creep up on the final color. If you make a mistake and need to start over, you can just wipe the area with an alcohol-soaked rag.
Be patient, and good luck! -- Paul
nailshooter
>I have had the same exact problem. As you suspect it might be for you, it was silicone squeeze out that had been cleaned at the factory with a rag. In other words, a vigorous cleaning with a rag at the plant that actually mashed the silicone sealer into the wood.
I have never found anything that would clean off the silicone and remove it from the wood pores. Only heavy sanding seems to do it, and that certainly isn't a workable solution on windows and doors.
Thankfully, I was able to show my client what was going on and get them to understand what happened. And thankfully, THEY purchased the large window with the problem. Having dealt with this silicone/sealer issue before, I had never found a good solution for it in regards to finishing. The clients were able to get a small amount of refund back from the manufacturer, and then we switched to a neat color of paint that looked great on the stained window jamb.
Good luck. I hope if you find a way to defeat the silicone pentration you will post the it.
Robert
how to remove silicone oil
Michael Dresdner
>Robert wrote "I have never found anything that would clean off silicone and remove it from wood pores."
The solvent for silicone oil is mineral spirits. Scrub contaminated raw wood with liberal amounts of mineral spirits and sop up as much as possible (don't just spread it around.) Follow that with a scrub of liberal amounts of warm water laced with household ammonia, which is a surfactant for silicone oil. Again, mop up as much as possible. This one-two punch will remove the lion's share of the silicone oil.
Thank you, Michael.
>While I'm leaning toward going with tinting the top coat (Quick 15, Satin) method, I'll try to convince my buddy to let me sand and re prep the door. If given a 2nd chance I was going to try some commercial "wax and grease" remover from an automotive paint store.
I have the ingredients you reccomend on hand so I'll probably go with your solution instead. I know he and I will always see the "fix" if I just work the top coat to hide the problem.
Re: Define silicone oil, please?
Al Stokka - Cambrige, Iowa
>Michael,
Most often your posts are clear and informative and I learn a lot from your technical knowledge. This time, however, I am wondering about your addition of "oil" to silicone. Is that an important distinction or are you being precise? Is all silicone properly silicone oil or are there two different chemicals; silicone and silicone oil?
Al
