Matched Bits for Glass Doors
Howard G
>I was looking at the Freud set. Would you recommend this or another brand? Thanks for the help.
Re: Matched Bits for Glass Doors
Bri in Mtl
>Howard> Are you talking about the Freud bits for making divided light doors?
If so, I've used them for a couple of projects and found them to excellent. Had good instructions for them in an American Woodworker mag.
Howard G
>Bri-
Thanks, what is the model # for the bit.
Bri in Mtl
>#99-270
Can't remember how much I paid for them but they ain't cheap.
Email me if you want a photocopy of the mag instructions.
Hank Knight from SC
>Do you recall the AWW issue that had the article?
Bri in Mtl
>Was July, 2005. Front cover had a big cherry hutch on it.
One thing about doing those doors is that a mortiser makes doing all the mortises a helluva lot easier. I think there's 8-10 mortises to do per a 6 paned door.
Charles M
>Howard,
Here's what the 99-270 looks like. You can also email me for a PDF copy of the article.
Thanks.
Hank Knight from SC
Another Router Bit Question
Howard G
>My Freud rail/stile bits are starting to make ragged cuts which sounds like they're getting dull. Would you send them out for sharpening or buy new? I know that sharpening will chnage the profile and could compromise the fit. Thanks for the help
Re: Another Router Bit Question
Charles M
>Howard,
It is normal to have them sharpened. Shims are included in the bits to adjust the fit afterward and you should be able to have them sharpened several times before the fit is unacceptable with shimming. Email me and I will send you instructions for adjusting the fit with the shims.
Charles M
Freud America, Inc.
