Have a question? Ask Woody!
Table top
Table top
Table top
Barry Daniel
>I am building a coffee table with a top of 23 x 52. Trying to find two pieces of cherry for the top has been very difficult. My local retailer suggested making the top out three pieces. His thoughts were 3 pieces would be more stable and I would agree; however, I wonder does it matter that much? What are you folks thoughts, thanks.
Barry
Re: Table top
Re: Table top
Pat Schupbach
>Multiple pieces would be more stable. Matching grain becomes an issue.Thicker stock you could re-saw and bookmatch. Good luck!!
Re: Table top
Re: Table top
Barry Daniel
>That was my first thought when the retailer suggested 3 pieces. Matching the grain with 2 boards would have been pretty easy, 3 near impossible. I was thinking about resawing, it would require a 12/4 x 9 x 53, that would be near impossible to find.
BL
Re: Table top
Re: Table top
DB
>Have you considered cherry veneered sheetgods?
If your local supplier orders a lot of cherry you should be able to get several boards that was cut from the same log with the same grain. The boards would be cut one after the other. I see this all the time in the lumber that we get at work but then we get large bundles all the time. Try to be the first person to go through the next shipment they recieve.
Re: Table top
Another idea....
>The resaw approach would allow you to bookmatch. I would be tempted to buy a 6" wide, 10' long piece of 10/4 cherry. Cut it into 2-5' lengths (Final length cutting to 53" done later) and resaw the two pieces.
You will wind up with 2 sets of 6" wide bookmatched cherry that should match in color because they are all of the same board.
Yes, you will have a top that is 4 boards. But constructed properly and attached to the base to allow for expansion should negate your concerns.
The double bookmatched look, while different from a 2 board look, will still look really nice.
Tom
Re: Table top
Re: Table top
David Hay @ Denver
>From what I've read, if a tabletop is properly supported, a few wide boards is no less stable than several skinny boards. The whole thing is going to expand and contract as if it's one large board, regardless of how many pieces are glued up. And as long as the top is attached firmly to it's base, any cupping or warping is likely to be negligible.
David
Re: Table top
Good idea, Tom!
Martin from Granbury
