OT - I can see through walls
Charles Sharp
>Well, kinda.
I was looking at the back of our church and notices some shadows on the stucco exterior. Then I realized that the shadows were of the framing inside the walls.
Is this is problem?
The church is about 50 years old.
Re: OT - I can see through walls
>There are a number of theories about why you can see what you are seeing. Most probably it has to do with temperature differences. The framing in the walls is at a different temp form either the air around it or the insulation around it. (Insulated or not Insulated?)
So there is a slight difference in the temp and this may cause condensation and mold growth in one area, but not in the other. Another theory is that the temp difference caused a difference in "Brownian Motion" which has to do with the movement or vibration of nearby air molecules. This in turn might have an effect on dust being deposited on the surface.
Is it on the north side where there is no direct sun? I bet it is in an area that is protected from "larger forces" that would obliterate these very slight effects.
I see it frequently on the inside of houses where smokers live. You can distinctly see where the framing is in the nicotine and smoke (dust) are deposited on the walls and ceiling.
I also see it on the exterior of houses built without vapor barriers in the walls. Moisture migrates through the cavities differently than the framing. (?)
Probably not harmful per se, but it tells you "something". Now if we could just figure out what it�s telling us.
Where are you? What climate? Is the church on a crawl space? If so, perhaps putting a vapor barrier on the grade under it might be good.
Charles Sharp
>The church is in Whittier (southern California), about 25 miles from the coast. The shadows I'm seeing are on the building that faces NNE. I doubt if there is a any insulation in the walls and as far as vapor barrier, it would be 15lb. felt at best.
