minimum sloap for shingle roof?
Ernie Miller
>What is the minimum sloap for shingle roof? I'm working on plans for a sun room and need to figure out several things befor going for a permit. first being the minimum slaop for the roof. and will 2X6's be strong enough for rafter if they are on a 16" cinter with a 14' span. This will be a flat roof comming out from the eve of the present house. I want to keep the roof sloap to a minimum as there is only 8'9" from the poured concreet floor to the top of the finished roof line. having the slope more than 1/2" to the foot will have the inside celing getting close to 7'7" or so which is getting a little low at the outside wall of the room. I als have a question about window headers. I will have 5 3' wide windoes right next to each other on the outside loade berring wall would it be better to run a continuse headder clear across the length of the wall or put in individual headers cost is pretty much a wash on that or might even be cheaper if they went clear across. Let me know what you all think or if you have a better idea.
