Jointer table alignment
wilbur
>I was tinkering with my jointer last night, and even though it is giving me a nice flat face, I decided to check the tables. Here's my situation:
-- The outfeed table is flat and parallel with the jointer knives.
-- The infeed table is also flat and parallel with the jointer knives.
-- A straightedge placed across the infeed and outfeed tables shows that they are not completely parallel with each other along the long axis of the jointer. Looking at the side of the jointer, the infeed and outfeed tables would make a very very very shallow V. The misalignment seems to be very minor, though.
Given that I'm satisfied with the jointed surface that I am getting, is this something that I have to address?
Re: Jointer table alignment
Rick L
Re: We need exact measurements..
Rick L
>It's only a problem if you can't get a good flat joint. It should be coplanar which is when your tables are perfectly flat. A V should give a crowned edge. I find it interesting that folks do all this measuring and never bother to assign a number value which I find a critical element. I repair machines so to me it would be described in exact numerical values such as with a 6' staight edge on a 6' overall bed length I have a gap of .010" at the meeting of the infeed and outfeed tables. Without this info it's impossible to give a good answer.
Drive me crazy when someone says it's off a bit or a touch. What's so hard about being more exact in the info?
Without the numbers the post is only half informative.
mdclor
>Some people are quantitative and some are qualitative. It drives my SIL 37.2% crazy that I am so quantitative. LOL!
Merle
Your last sentence says it all....
John in New Mexico
>If you're satisfied with the machine's performance, why mess with it?
John
wilbur
>Rick,
As you requested, I went and measured the gap. The longest straightedge I have is 40 cm (15.7"). Bridging the infeed and outfeed tables with this straightedge I have a gap of 0.015".
Now that you have this data, I look forward to your expert advice. Do I need to correct this?
Up to you, Wilbur
>I personally would fix a .015" gap on a jointer bed, but if you're getting good results, why change it? If you can joint two six or eight-foot boards and not have any daylight at either end or in the middle when you put them together, that would be as much as you need to ask of that machine.
A jointer that is misaligned in this way will theoretically yield crooked edges if everything else is aligned correctly. That's because the leading edge of the board, after it passes the cutterhead, begins to rise with the pitch of the outfeed table, resulting in a slight reduction in the depth of cut and a slight crown on the length of the edge. If you're not getting this result, it may mean that something else is compensating for it, e.g., your cutterhead is set higher than the outfeed table. This condition, on a jointer with coplanar tables, results in a concave edge. So, in effect, you have two errors offsetting each other.
While you are getting acceptably straight edges, this misalignment may be causing other problems or results that you aren't tuned into. For instance, there may be a tendency for more vibration in some conditions, resulting in more of a washboard texture to the edge. This is because of the reduced outfeed support as the work leaves the cutterhead. It wouldn't appreciably affect short pieces. It would be more noticeable on long narrow pieces or when face jointing. This may not be a problem for you, but you might want to have a closer look, and also be conscious of any odd feed pressure or vibration issues. If you've ever used a really well-tuned jointer, you know the feeling of a board being really flattened. On an old Oliver that I tried once, it actually felt like there was a suction created when you went to lift the board after a pass. Sorry to wax so poetic about something as mundane as the experience of a well-tuned machine.
If you want to fix the problem, assuming you have a wedge-bed machine, I would suggest getting a few scraps of brass shim stock in different thicknesses, say somewhere in the range of .001" through .010". You could calculate the amount of shimming needed, but trial-and-error and educated guesses are probably the way to go. I recommend placing shims in the outfeed table ways nearest the cutterhead. To do that, you need to loosen the gib screws enough that you can get your shim stock into the space between the table ways and the base ways. Tighten the gibs again and re-check the flatness of the tables. Adjust the thickness of the shims as necessary. Once you have it perfect, make sure the height of the outfeed table is set exactly at or a couple thousandths below the arc of the cutterhead knives. That's another trial-and-error adjustment that affects the straightness of your edges.
Ellis Walentine, Host
Rick L
Re: You already answered...
Rick L
>Since you are satisfied with the flatness of the face I would say no!
A proper measurement requires a straight edge 2/3's the length of your bed length. I just find that folks don't put enough info on their posts. If something is off 1/32" just say so. Saying a bit or a touch means nothing. It might be perfectly in tolerance. For example the old Oliver allowed .010" on the flatness of the 16" jointer table which was 48" long per each table. Mine was warped by .016" which didn't give a suitable edge. For many it might not be noticable. For me it was as I set up machines for other folks so my standards have to be higher.
