New House New Shop Almost
Dustmaker Mike
>Well after two years of Renting I guess I am ready to buy a house. I have been looking around and find that the older aluminum & vinyl covered houses need to be redone. I think I can repaint them but can I? I was also thinking of takeing off the aluminum sideing and replaceing it with vinyl then sell the aluminum as scrape, to pay for the vinyl. I have not found a house yet but just getting my Honey Do list ready.
Re: New House New Shop Almost
Rich Schneider
>You can repaint the aluminum siding...there are a few issues to be aware of and consider before taking this approach....one, you need to powerwash it to clean and remove the chalkiness of the old finish, when you do this you need to be careful to wash in the downward direction to prevent blowing water up under the laps of the siding..two, then you need to let it dry really well and not just overnight, a few days at least...three when you paint it use some Emulsabond mixed into the paint to improve the bond with the existing paint (you need to spray it on not roll or brush it or it will look like crap)..a pro paint supply shop will have it and can tell you the right ways to mix it...if you follow the label it will be a little too much Emulsabond..but again get local, reliable, advice on it...you need to be very consistent in the mix since Emulsabond is white and will lighten pigmented colors..four, realize that aluminum will expand and contract, so you use a different color from the oringial you will likely see a line of the original color at the joint when the aluminum contracts in cold cold weather....you can also do the same thing with vinyl as well...the risks are 1) the joint color I talked about above, 2) if you don't prep correctly or use a bonding agent like Emulsabond you run the risk of sheet peeling..3)paint life is approx 15 years at best, so you'll be doing it again in the future...I've done this with steel buildings, aluminum and vinyl siding with good success, but realize that its not like new siding..dents, dings, holes, etc will still be there and will show even worse after painting...you may be farther ahead to recylce the old and go with a top quality vinyl or a steel instead.....
If you are fong to remove the siding
Don Henthorn
>do yourself a big favor and replace with Hardiboard.
I can spell, just can't type.
Don Henthorn
Ed Wozniak--Buffalo, NY
>Aluminum siding can be repainted. As Rich says it has to be power washed first. Sometimes just power washing is not enough. Sometimes it takes power washing and a lot of scrubbing to get it clean enough to allow the new paint to adhere. I have brushed water based paint on to aluminum siding with good results. But that is an interesting idea you have about selling the aluminum and using the proceeds to buy vinyl.
Pete LaBelle
>I don't think you have nearly enough aluminum on your house to pay for the vinyl.
I have aluminum on my house. ALL of the old paint chalk needs to be gone. Pressure washing alone didn't get rid of it. TSP (trisodium phosphate) detergent, a little bleach in a bucket of water cuts the chalk easily. Wet the area, wipe it on with a car wash brush, then rinse it off. Make sure to rinse windows thruoughly, as the rinsed residue will harden and make a mess of the glass. Once you can't get any chalk off on your fingers in a wipe test, paint with an acrylic latex paint. The acrylics will leave the paint flexible to move with the aluminum thru the seasons. Painted the house with this technique in southern Michigan 11 years ago and still going strong with no issues.
Pete
Thanks All
Dustmaker Mike
>Like I said I have not bought a house yet but I have seen some really nice places for sale needing a little TLC on the outside. I was not sure if painting would work but after reading here and a few places on the I-net it is do able thing. Now I can get them down in price Yiippeee
