veneering plywood
veneering plywood
veneering plywood
Wayne Carson
>I need to veneer some 3/4" red oak plywood with some white oak veneer do I need to do both sides. It is going in the bottom of a oak ice box. If I don't do both sides will it bow enough to notice for that purposemit will be about 22x40".
Re: veneering plywood
Bill Tindal, E.TN
>I did one side of some 1/4" birch and have had no problem, but the piece veneered is a cabinet back and it is well restrained.
Joe Burke
>Coin toss. It might never give a moments problem. I'd put it like this ..... If you have the veneer and it's an easy operation for you, then why not veneer both sides? If it'd mean buying extra, or more than what you have, and it's an operation that's a task for you, then just get it done once.
How important is the project? Is it for you or a client? Who will it affect if there's a problem? Just questions to factor into the decision.
My first thought was to be sure to lay the veneer perpendicular to the existing face veneer. If that's old news I apoligize.
wood vaneer on MDF
Wayne Carson
>The cabinet is a repo. of the old ice boxes I am doing for the wife and the veneer is quarter sawn white oak. I just hate the thought of using QSWO on the bottom of the base where it won't be seen. I have been using hide glue and it has been a wonderful learning experience but is time consuming. What is the reason for going perpendicular to the original veneer.
Re: wood vaneer on MDF
Tom Stockton
>I would do both sides. you don't have to do the hidden side with the fancy grade. I use what is called backer veneer of the same species ,for things that aren't seen it is not that expensive and for something that small one piece is all you need.
Tom
