Cabinet levellers *LINK*
>I placed a long, reasonably straight 2 x 4 on my shop floor - surprise, it isn't very level. Gosh, oh darn! OK - I pretty much figured it wasn't level. So, I am planning on incorporating levellers underneath the cabinets and using the LV brackets and leveller feet (http://www.leevalley.com/hardware/page.aspx?c=2&p=40045&cat=3,41306,41308).
Does this sound/look reasonable?
(Taking a break from drawing and compiling a lumber list. Also escaping the smells of baking from the kitchen!)
LV Leveller bracket
Re: Cabinet levellers *LINK*
Larry Marker in Alabama
>Seems reasonable to me. I've had to put levellers on all my machine stands, outfeed table, etc. that I built for my basement shop.
Larry
Curly Smith
>I've had good success using these from Rockler:
Heavy Duty Lifting Leveler
on some weight accumulating cabinets. They're rated for 600# each and are $16 for a set of 4.
Re: Not bad for a set of 4.
>I can pick them up at Rockler also. Thanks for the tip.
Don in Northern Arizona
>Jerome,
Here is another option that I used on the vanities and cabinets in two bathrooms. You may not be able to get them locally though. You build your cabinets and set them on these, twist them up or down to level them, and then custom fit kick plates to the uneven gap which can clip on to the levelers using the supplied clips.
Don
http://www.tablelegsmd.com/detail.aspx?ID=490
Joe Burke
>I'd go with the ones from Rockler, although Woodworker's Supply has them also. With these the cabinet actually rests on a lip on the leveler. That's as opposed to the other where the cabinet is actually supported by the screws that attach the leveler to the cabinet. This might be too picky, but with heavy cabinets why take the chance?
