220 jointer back to 110?
Lee Beeden
>I just moved into my new shop and need to convert my delta 6" jointer back to 110 for a couple of weeks until the electrician can get here(there very busy). It did come pre-wired for 110 and I had it chenged to 220. I opened up the box but there is no diagram. Convertin the table saw back was no problem because there was a diagram. It seems there are more wires then the jointer................electrics is not my thing. Also not all the wires are numbered. I have the instrction manual and there is nothing in there, also tried the dewalt site and downloaded a pdf file which ended up being the same manual.
any ideas
Lee
Re: 220 jointer back to 110?
Paul Mosteller (Springfield, VA)
>I've got a Delta 6" jointer model 37-190 that's about 10 years old. There is a wiring diagram on the motor with the wires grouped odd then even numbers.
For 110 it shows wires 1,3&5 tied together and 2,4&6 together.
For 220 it shows wire 1 seperate, wires 3,5&2 tied together, a 4&6 together.
>I just opened it up. On mine wires 1 & 2 are white and 2, 3, 5 & 6 are black.
So to change mine from 220 to 110 I'd group the wires like this:
220: 1 352 46
110: 135 246
Hope this helps.
Different on/off switches ?
>My paperwork shows a seperate switch, hope you still have the old one.
Re: Different on/off switches ?
Bill Howatt
>Normally, the 220V machine is supposed to have both hots interrupted which requires a double-pole switch. In the 120V operation there is only 1 hot thus requiring only a single-pole switch. There is nothing wrong with also interrupting the neutral so the double-pole switch is OK.
Normally, the current/voltage ratings are OK for the switches since the HP remains the same and the increase in current is offset by the decrease in voltage. This doesn't always hold though.
Bill
whats your # Bill...I bet you could talk me .....
Lee Beeden
Check your email!!!
Bill Howatt
Re: Check your email!!!
Lee Beeden
>thanks bill but the wires are black with numbers or white without,there is no diagram on the motor and nothing that represents it on the attachment you sent. the motor is a 1hp 120/240 volt induction motor, jointer model 37-195 or model 37-275x ....delta
thanks for your input
lee
Bill Howatt
>The only thing I can suggest apart from waiting for the electrician or hoping somebody can be more definitive is to carefully mark or label the unlabelled wires and make a diagram of the existing 220V connections (what wire is connected to what wire and whatever else).
Try and match up your connections (total number, number of wires connected together, free wire) with one of the diagrams in the file I sent you. The numbers won't necessarily match. Then free up the wires from each other and using an ohmmeter verify the windings and the diagram match. The start winding with the capacitor in the circuit would cause the meter to kick and then fall to a high resistance. Once you have it verified you can then make the corresponding 110V connections.
Since you aren't an electrical nut you probably don't have an ohmmeter though.
Best I can do,
Bill
Re: Thanks Bill!!!!!!!!!!!!!!!!!!!
Lee Beeden
>Thanks for all your input Bill, i think i'll wait for the electrician!!!!!
Take care
Lee
>I have wired my shop and a few houses. I have changed a few machines from 110 to 220. I even had lunch with Sam Maloof. I would be far more comfortable wiring a temporary 220 electrical outlet than trying to change the motor back and forth without a diagram. If the panel were even fairly close by I might take the cover off and wire a 220 outlet onto the circuit with the dryer or add a new breaker and plug the jointer into that until the electrician came. At my skill level I know I can do That without killing myself or ruining my jointer, but If I went to switching the wires in the motor around, I would not even be surprised if I let the puff out.
