OT: Paint Question
OT: Paint Question
OT: Paint Question
Bill Kay
>I was given a new 5 gallon pail of semi-gloss latex. The problem now is ... Boss really likes the color and dislikes the sheen. Is there a way change the sheen? Possibly a flattening agent or other chemical?
Probably never should have taken the lid of the bucket and said "How Do You Like This Color?"
Regards,
Bill
Re: OT: Paint Question
Jason Roehl in Mulberry, IN
>Well, if it's too shiny, you could add some talc to make it flatter. Latex/acrylic paint is naturally semi-gloss. Talc is a common additive to make it flat, though I don't know how it differs from the "baby powder" variety. If anything, I would guess that it is of a finer grind and added in such a way as to prevent clumping. I know there are other ingredients used to flatten paint, I just can't think of them right now--I've just been putting the paint on lately, not reading the labels. If you want to get it shinier, then you would have to topcoat over it with a higher gloss of something like polyurethane. Come to think of it, there are matte waterborne polys available with which you could over-coat.
Years ago, when I was first using the products from a particular vendor, I went to paint my parent's house. I didn't like the "eg-shel" sheen they offered, as it was too shiny in my opinion. So I mixed it 1:1 with flat in the same product line and color, and ended up with a fairly flat sheen that my mother says cleans easily and does not burnish.
You'll notice that cheap, flat paints are VERY flat, chalky-feeling and burnish easily. I believe that is because talc (or whatever else is used) is cheaper than the paint. Higher ratio of talc to paint equals cheaper flat paint. They tend to have a lower solids content overall, too. I've actually found that these cheap flat paints make for good primers on bare wood in a pinch, as they sand quite smooth after priming, knocking down raised grain and taking off most of the roll, brush or spray texture that may have occurred.
Jason (Addy protocol: pro painter)
additives
Michael Dresdner
>While you can buy flatting agent, and it is common for lacquers, it is rare to find it in waterbased versions, though I did find two while researching an article. Most flatting agent is fume silica. Both talc and barytes are used as bulking agents. The problem is that it is quite difficult to mix any of these fine powders into thick paint without it forming clumps, and the finer the powder, the more difficult it is to mix. Sadly, most paint stores will not or can not do this for you.
You can do it with a drill press using a G or F Cowles or Hockmeyer blade, which are high shear blades, but do be cautious about getting it all mixed well. Your odds will be better if you premix the flatting agent into a solvent, then blend that into the paint. Floetrol would be an appropriate pre-mix solvent if you plan on using it anyway. My guess, though, is that you do not have access to a high shear mixing blade, so unless you can find a stir-in version designed for paint, you have a problem ahead of you.
Of course, you can always buy the same color in deaf flat, or the lowest sheen they have, and mix the two, but then you will end up with way more than you probably need. Flatting adjusters fall squarely in the same realm as board stretchers.
Bill Kay
>Jason and Michael,
Thank you for the response. I might try the cheap flat as an additive to see how it works.
Thanks Again,
Bill
