Have a question? Ask Woody!
Rigid Drill Press Chuck
DWA
>I was using my Rigid Drill press today and low and behold the chuck stop working.
Let me ellaborate. I needed to adjust my chuck to accept a 1/2" shank. Adjusting it was not a smooth operation. It was a little sticky. However, I was successful. When I tried to adjust it to a smaller shank size it would only adust a little bit.
I tried everything I know: lubricating, opening and closing the chuck and nothing worked, so then I tried to remove the chuck but noting I've tried so far is working, and my frustration was starting to grow, so I decided to back off and cool down.
I emailed Rigid. hopefully they will have a solution for me, and I also requested a replacement chuck. Lets see how well they back their name.
My next option is to apply heat to expand it enough to help with removing it, but before I try that I thought I'd query you guys for suggestions.
I thank you for all your help in advance
Re: Rigid Drill Press Chuck
Rob Hix - King George, VA
>I have only had one problem with my Rigid drill press, and I have nothing by high praise for the way it was handled. Shortly after I first bought it, it was drilling holes larger than the bit size. Not by 1/32" or so, but more like 1/16". It did not seem to matter which bit I used. Called them up and they gladly sent me a new chuck. When it got here there was a note in it saying it had been tested for trueness and gave the measurements that they measured. Pretty cool if you ask me.
The drill press is the only piece of equipment I have that is Rigid, but I would not worry for a minute.
Rob Hix
replacement or refund Re: Rigid Drill Press Chuck
del schisler
>if you havent had it for very long We say around 6mo I would go back to HD and to the tool dept and tell them about the chuck And ask if they would replace it They may take one off of the desplay model If you know them very well If not tell them that you will bring the WHOLE unit back for a replacement Or refund I work their Some times they will go for the easy way out. Try it
