Glue for green lumber
Bart Goldberg
Bart Goldberg
>I'm making some trellis for my vegetable garden. I purchased some rough sawn locust and was looking for advice in gluing it up. I plan to attach the pieced using deck screws and probably poly glue. Should the poly glue work on lumber that is 16% moisture content?
Thanks
Bart
Re: Glue for green lumber
Chuck Lenz
>If I remember correctly, when useing Gorilla Glue they tell you to moisten the surface before glueing. I would think that or any other poly glue would be the correct glue to use. Atleast thats what I would use. If you want to be 100% sure, I would contact the company that makes the glue.
Howard Norman-Prescott, AZ
>I have been using Gorilla glue for outside projects like that. So far no problems, except when I get it all over my hands.
Howard
Gorilla GlueRe: Glue for green lumber
del schisler
>i would use Gorilla Glue for that I have been using Gorilla Glue sence 1989 I belive that is when it came out The glue is the best i have used It will not clogg your sanding belt's Nothing breake's it down when it is harden Nothing It tell's you to use gloves when you use the glue Water will not take it off All it does is stain the skin The item need's to be clamped When the glue start's to harden it seep's out or expand's You can keep cleaning it around the seem's That's what i do A little goes a long way 1 small bead down the board is all it take's Of course it depend's on how big the board is To much is better than not enough
