THE WOODRAT IS BACK!
O.T.: Computer monitor display problem
David Sparks
>I've got A Dell computer running Windows XP with a flat panel lcd monitor. Recently the monitor display started jumping erratically, kind of like an old tv when the horizontal hold was out of adjustment only worse. The display doesn't scroll completely, just up and down really fast. It gets worse when the computer is restarting and gets a little better after all the programs have loaded. I'll appreciate any help with this.
Re: O.T.: Computer monitor display problem
ScottS
>LCDs don't refresh like a TV does, so in theory shouldn't be the LCD that's the problem. Although with all the electronics they put in them, who knows?
My guess would be it's your cable or, perhaps, your video card. What type of connection are you using? Is it digital/DVI (cable usually has white ends) or analog/VGA (cable usually has blue ends)? I'd check to make sure that your video cable is securely attached to both the monitor and the computer.
If your problem isn't a loose cable, then diagnosing the problem gets more tricky. You could try:
1) Using a different cable to connect the computer to the LCD
2) Connecting your computer to a different monitor, if you have one available.
3) Connecting a different computer, if you have one available, to the LCD monitor.
Do you have another computer?
Ron in Drums PA
>Try swapping monitors. If the monitor works on the other system you know it's the video card.
Did you play (or someone else) around with the resolution settings?
PaulA
>You got some reasonable things to try from Scott. One additional source of problems is a poorly seated video card so you might want to open the computer, and remove the video card (assuming you have one, you may have your video integrated on the motherboard)and then reseat the card.
Scott is misinformed about LCD operation. LC monitors refresh exactly like a TV and your symptoms suggest a problem in the vertical sync signal. The problem could be in the monitor, in the cable, on the video adapter or the connection from the motherboard to the video adapter. It might also suggest a power supply going south, but try the easy things first.
Paul
ScottS
>Actually, Paul, I'll have to disagree with you on refresh. To start off with, most CRT monitors these days can refresh at multiple frequencies ("multi-sync") and can display many different resolutions. LCDs, in constrast, have a fixed refresh rate (60Hz) and a fixed resolution. That's a big difference right off the bat!
In addition my understanding, which admittedly is somewhat limited, is that data transmitted digitally via a DVI cable is not required to be synchronized to the display rate of the LCD like the video signal on a VGA cable is. In fact, this is one of the benefits of using DVI: it can, theoretically, transmit data at much higher speeds and the timing can be independent of the refresh rate of the display. Of course, the whole issue is muddied when you start talking about the differences between DVI-I (digital-only signal), DVI-I (digital and analog), DVI-A (analog only), etc.
Of course, if you have an LCD monitor which uses a VGA cable, it receives an analog signal from the computer just like a regular monitor. In which case, the video sync signal might be the cause of this problem.
David sparks
>I opened the computer's housing and checked the video card to see if it was loose. It didn't feel loose, but when I closed the case back up and rebooted , the display worked fine. I don't know how long it will work. Thank you for all the help.
PaulA
>Scott
"Actually, Paul, I'll have to disagree with you on refresh. To start off with, most CRT monitors these days can refresh at multiple frequencies ("multi-sync") and can display many different resolutions. LCDs, in constrast, have a fixed refresh rate (60Hz) and a fixed resolution. That's a big difference right off the bat!"
The operation is a bit different than you stated. A given LC monitor has a fixed number of pixels, but those pixels can be addressed in numerous ways and refreshed at different refresh rates, including above and below 60 HZ. So, for example, a 1280 x1024 monitor can be run at 1024 x 768, or 800 x 600 or any other "standard" that the monitor driver is programmed for. When it does this the pixels are remapped and depending on what you are doing you may not like what you see, but it is done all the time.
Data transmitted to the display, whether digital or analog HAS to be in sync with the refresh signals. One of the real benefits of DVI is that one of the signals transmitted to the display is the pixel clock signal so the pixels will be jitter free no matter what the data rate. VGA does not have a pixel clock signal and the clock has to be recreated in the display from the sync signals leading to time jitter in some cases and especially at higher data rates and with cost reduced electronics.
VGA signals can drive both CRTs and LCDs. That works because they are both refreshed displays, they are both multi-sync capable, and they both have to have the data locked to the horizontal and vertical sync signals.
Wow! this does not sound like a woodworkers forum. Did I mention that both type displays can have wooden bezels with dovetailed corners.
Paul
