>Well i just moved into my new shop, but its still a mess; everything is in boxes and i can hardly move. I've been looking forward to this though, time to re-organize. First its a new mitre set-up, then mobile bases for some machines. I think its also time to get a better set up for the dust extractor. Take the shop to a new level!!!!
Any ideas on organizing?
I'd love to see any pics, chisel racks, lumber racks...........i need inspiration.
>I posted a query on lumber storage last week. Here is a link to the discussion. I'm still vacillating between the Lee Valley System and the home built ones. I'm still moving stuff from the garage down to the shop.
>sounds like you have taken the first step, that is thrown out everything that you don't truly need. like most problems, that first step is the hardest. Jerry Gibbs
>I started putting French cleats around some of my walls at 3 different levels and I've like the versatility that give me. I made clamp racks and peg boards to fit on them, and moving them later to reconfigure is a simple lift and slide job. Plus them you're not limited to finding studs to hang everything on.
>I've never been the most organized person but when I inherited a truckload of shop junk and hardware from my boyhood home, I had no alternative but to knuckle down and organize it somehow. In the course of many nights and weekends in the shop, I had quite a few aha! moments regarding the most efficient way to get from point A (utter chaos) to point B (order), not that I will ever get there.
One of the things that I found myself doing was moving stuff from one place to another, in the general direction of where I wanted it to end up. All this was based on a floor plan I had in mind that would accommodate all the tools and functions I wanted. As I was moving things, I was consolidating -- moving things from bigger boxes to smaller ones and throwing as much as possible in the burn pile. Gradually, I got 90% of my shop fixtures and storage units built or upgraded and started consolidating junk into those areas. That enabled me to put stuff away and concentrate on the systemic kinds of layout changes that will finish the job.
I liken it to a Rubik's cube because it's very hard (for me at least) to envision the end result I want, but it's easy to make the next incremental step in that direction. I guess another way to look at it is to decide on what types of stuff you are trying to organize and then work first on creating that space. Then it's a matter of moving your miscellany into the new spaces.
I realize this is a pretty abstract way of looking at it, but it's a concept that hopefully can help you along.
I always liked the Taunton Press book "The Workshop Book" by Scott Landis as an idea generator. If you have a local bookstore, it might be worth a trip to browse through it. Good luck and have fun organizing all that stuff!
>The best recommendations I can give you are as follows:
-Spend an hour or two looking at the shop tours (under the Odds and ends section at left). Make notes, use the ideas
-Next is to think 3D... use the vertical space. If one tool has a higher in or outfeed than another, you can therefore overlap the in and outfeed areas to maximize space usage.
-Also check out my lumber rack shop shot linked below. I am about to move into a larger shop and plan to use this same rack there, as well as add another one just like it only A-frame and free standing (thanks to the idea, Ellis!). Lots of safe lumber storage with easy access from the sides for picking through.
