Need a 4" adapter
Need a 4" adapter
Need a 4" adapter
jeff
>Hi all
I need to find a supplier for a 4" to shop vac (2 1/2") adapter.
Most of them are the type that fits the 4" pipe (male fitting).
I need the type to go onto the 4" outlet of a tool (female fitting).
Everyone sells the first type (male), but not the second type (female).
I bought one 3 or 4 years back (so I know their made), but can't seem to find it now.
Anyone one know off hand who sells it?
Jeff
Re: Need a 4" adapter
Re: Small section of 4" hose and two clamps!
Kris Lasure
Re: Need a 4" adapterWhat I did
Lee Schierer, McKean, PA
>I use my shop vac hose on my Dust collector to sweep the floor. I had a similar problem. What I did was to take two pieces of 3/4" wood, glue them together to make a block 1-1/2 thick and the same dimension on a side as the inside diameter of the 4" pvc pipe fitting. I used the circle cutting jig for my band saw to cut the OD to size. Then I used a hole saw to saw out a circle in the center of the disk, creating a donut. A little sanding with my spindle sander and I had a reducer. The vacuum holds the piece in place. If it slips a bit, run a thin layer of silicone sealant around the outside circmference and let it cure, it should be enough to hold the adapter in place.
Lee
Try Penn State Industries or Jet
Dave Bair, Eaton Rapids, MI
