Re: aftermarket pc 7539 micro depth adjustment ?
Dave Morris
>John, since nobody has offered any good advice, I'll take a SWAG... I'm guessing you mean that "fine tuning" the depth of your rabbet is kinda hit and miss-- too much, or too little, but danged hard to get it right.
Try this: Get it as close as you can visually, take a test cut. Too deep? Set a piece of paper on the bottom of the rabbet so only the bit touches it, then re-adjust the depth so the rest of the router base in now on the flat surface of the piece being rabbeted. You've just adjusted your router about .002" to .004", depending on the grade of paper.
Too shallow? Put the paper under the router base, and then re-adjust the bit so it touches the bottom of previous rabbet that was too shallow. The bit will now cut a rabbet that is one thickness of paper deeper than it did before.
No, it's not high tech, but it works. I've also used paper to fine-tune the position of my router table fence for sliding dovetail cuts. Again, it's not pretty, but it works.
Dave--- who *still* can't remember if it's "rabbet" or "rabbit". Oh, well, you know what I mean...
