Way OT, sorry Bri
Way OT, sorry Bri
Way OT, sorry Bri
Pete In Millgrove
>Any mechanics out there ? I have a 2003 Chevy Venture, which has been acting up lately. It never seems to get warmer than 70/75 degrees lately. When I turn on the heat it seems warm enough , but as soon as I stop driving it starts to blow cold air. Any suggestion, could it be a thermostat problem ? TIA PK
Re: Way OT, sorry Bri
Rick Christopherson
>I'm not a mechanic, but there are a couple of simple problems. First, check the fluid level. Next, it could be water pump or a loose belt. The fact that it blows cold air when you idle tells me it is related to not moving enough water through the system. Just because the gauge reads cold does not necessarily mean the block is cold.
LOL..lemme know. I have a Venture too.
Bri in Mtl
HC Sakman
>It's probably leaking coolant through the head gasket. Mine is 1997 and replaced it at 40kms. (that's less in miles) and at 60kms. trans. got seized. I pledged not to buy another North American vehicle as I also had a 94 Chrysler with fried trans. at 60kms. 2000 Impala with leaky head gasket and GMC Safari with leaky piston rings burning oil. Except Impala, none was done under warranty. I don't put enough of miles within the warranty's time frame, otherwise all of them were bought brand new.
Impala... I traded-in rather than spending $1200 to replace $50 gasket. Enough is enough!
Top the coolant level. Mine is leaking again. I'll be getting a Toyota Sienna. Good luck!
Chico...
NM: It Sure Sounds Like a Thermostat Stuck Open
Paul Leuba
Well... There's some evidence in my case.
HC Sakman
>Occasional wet spot on the driveway, right under the engine tells me otherwise. I got it checked 2 months ago, they couldn't spot the leak as warm engine evaporates the water (I guess).
It may very well be that for the original poster's Venture. Just telling my experience.
Chico...
I Think
Jim Shaver - Oakville, Ontario
>It's the sweat dripping off the block, from sitting next to that white 330 in the driveway, who wouldn't?
Take care,
Jim
She better sweat...
HC Sakman
>...just about to get her rear bumper kicked to the scrapyard! ;-)
Chico...
