Have a question? Ask Woody!
Faceframe & Rail/Style wood shrinkage
Bri in Mtl
>Well this is a lesson learned -I'm getting enough separation between vertical and horiz. parts to cause unsightly(to me)cracks in several faceframe and even the rail and style joints of the upper doors in of a couple of milkpainted hutches I've built.
Wondering if this has happened to others with painted furniture.
Re: Faceframe & Rail/Style wood shrinkage
here's mine ...
mike farinella
>I didn't have that problem with mine. Although admittedly, mine is no where near the craftsmanship of yours. I used poplar for the face frames, doors, and shelf fronts. The top is pine. The rest is birch ply. I also live in a dry, arid part of the country (SW Las Vegas).
I think your design is quite awesome.
Not my design
Bri in Mtl
>Thanks -Got plan from American Woodworker mag a couple of years ago.
>The stiles are pretty wide in that design and the shelf, top, and molding of the cabinet are probably preventing the width of the cabinet from shrinking. If you used pine or poplar then I would say the design was doomed for failure from the get go. Even professional designers sometimes do not really know how to design for wood movement. In the future if you used such wide stiles you would want to leave room between the ends of any horizontal pieces and the case sides for shrinkage. The door stile/rail joints will normally show a small crack when painted just from the normal movement of the wood but the size of the crack would also depend on the joinery used.
Bri in Mtl
>Actually the top simply sits on the top section so I don't have any problems with the top.
Thanks for the reply.
Rick Snyder
>Hello Bri
I'm wondering what your technique was for making the glass doors and more specificly the mullions and their attachment to the rail and stiles.
Thanks, Rick
Re: Faceframe & Rail/Style wood shrinkage *LINK*
Bri in Mtl
>The plan for the hutch in American Woodworker(July/o5) has an article on how to make the doors with the special divided lite bits.
Dorr bits.
Rick Snyder
>Thanks Bri for the the reply and the added info. Found my issue A.W. '05
Rick
