THE WOODRAT IS BACK!
Rockwell tablesaw repair?
Felix Sarubbi
>Hello,
I have a late 1940's vintage Rockwell 8" Arbor "Homecraft" table saw/4"joiner. The cast piece below the table has a sort of gear molded right into it, and the screw assembly that tilts the table articulates against it. The gear slots for the first ten degrees or so (between 78 and 90 degrees of adjustment) are mashed. I have contacted Delta for a parts list. Can you suggest any way to make a repair? The saw is servicable, you can just set the angles carefully "by hand" for the ten degrees in question, but the saw belonged to my father, and I would like to restore it, if it would not be too expensive. The serial number is 88-8027. Thank you.
Felix Sarubbi
Re: Rockwell tablesaw repair?
Rick L
Rick L
>The Delta part is the way to go. A machine could make the part but it would cost many time the price of the whole saw.
