One thing to look at...
John in New Mexico
>They've got a new(ish) type of tub, that just blows air out little holes rather than circulating water through the jets. Supposed to be quieter and much easier to keep clean (we used to do bleach washes on the last one to get the scum out of the lines). No idea yet how well they work.
I think you're on the right track with the skirt, cheaper to build it, and it looks better too. With a corner unit, the skirt will probably be straight pieces, so not too hard to build. I've been doing a framed mini-wall with 3/4 cdx top that then gets a skin on the sides and top. We've done teak for the top, and the latest will be walnut. If you did some kind of frame and panel sides, you could make them a little big, scribe to fit and just attatch to the structure behind that holds up the deck. Make one hinged for access, or even just with some brass screws, as you rarely need to get in there anyway.
Sounds like an interesting project you got going!
John
