24T CMS Blade
24T CMS Blade
24T CMS Blade
Kevin French
>I'm planning to build an addition onto my 'Deck' (33 x 6 open porch). I going to use 'Eon' composite decking. They reccemond a 24 or less T blade for CMSs to protect against burning the decking.
Anyone heard of such an animal?
I called my blade sharpener, Systi Matic has a 60 or 70T for CMS but no lower.
Re: 24T CMS Blade
Re: 24T CMS Blade
ScottS
>I used a 40-tooth, 12-inch blade on my miter saw while building my Trex deck. Didn't have any problems with it. Amazon shows a couple of 32- and 36-tooth blades for 12" saws, but I didn't see a 24-tooth blade...
Re: 24T CMS Blade
Re: Oldham, DeWalt, Bosch
Al Stokka - Cambrige, Iowa
>Search for "24T 10" blade" (no quotation marks) with Google. You find a number of them.
Al
Re: 24T CMS Blade
Re: 24T CMS Blade
Pat Schupbach
>A 24T blade is a rip blade, cant see it to effective for a miter saw.
Re: 24T CMS Blade
Re: 24T CMS Blade
Kevin French
>I know it's a rip blade, but "Eon" reccomends a 24T OR LESS to prevent burning the decking.
I found a Freud 44T so far the lowest 12" blade
Re: 24T CMS Blade
Re: 24T CMS Blade
ScottS
>As stated earlier, Trex recommends the same thing and I didn't have any trouble using a 40-tooth blade. Not one single burn mark on any of the 300 sq. ft. of decking I cut.
Amazon seems to sell quite a few 12" blades with a 1" arbor and less than 40 teeth. Since you seem hung up on the 24-tooth number, try searching for the Freud's LM71M012 12", 20-tooth rip blade. I found it under 12" miter saw blades, but it also shows up as a 12" tablesaw blade.
Re: 24T CMS Blade
Re: 24T CMS Blade
del schisler
>here is a link for the blade
http://www.amazon.com/exec/obidos/ASIN/B0000225UH
