A55 Smoothing Plane
METAL CUT OFF SAW
METAL CUT OFF SAW
METAL CUT OFF SAW
woodie1
>Anyone have any thoughs on metal cut saws?
Thanks
Re: METAL CUT OFF SAW
Tom Dunlap
>The Ryobi 14" saw that I bought years ago has chopped up lots of iron. The motor has smelled as bad as the burnt metal and it still runs. I've found that Ryobi tools are a good value. There are better tools but the costs are sure high.
Jay St. Peter
>I bought an abrasive metal cutting blade for a 10" miter saw that I replaced with a (supposedly) nicer 12". It has been working like a champ for a couple years now. I haven't cut a ton, but have worn down 2 blades. I have to blow it out to change the cut angle as the metal dust hangs the mechanism otherwise. I really expected the heat to destroy the thing in short order, but so far so good.
I'll probably get the Ridgid as a replacement when this one goes. It seemed like a good value and looked a little nicer than the cheaper ones last time I looked. But, I haven't looked lately as I'm starting to believe this one will last a while.
Jay St. Peter
John Foster
>I have a 14" Jepson which has performed reasonably well. The big question is how much cutting are you going to do? I bought mine when I still farmed, and used it to cut metal to build gates, bale racks, penning, machinery repair etc. Had I known how fast I would go through abrasive blades I would have purchased a metal cutting bandsaw, or a power hacksaw. Now that we are off the farm I use it much less, and go through only a blade or two a year.
Messy, dirty, noisy......
>I have a 14" abrasive cutoff saw. It works well, but it's very messy, dirty and noisy. I don't use it in the garage because of this. Instead I put a few 4'x4' pieces of scrap plywood out back (to contain the sparks) and use it outside.
It's my least favorite tool to use, I think.
In fact, a few years later I bought a Milwaukee portable metal bandsaw (like a mini banksaw that you hold in your hands) and I prefer it much better. It cuts just as fast as the cutoff saw when accuracy doesn't count. With patience and experience, I can use it to cut steel with as much if not more accuracy than the cutoff saw.
I use my metal bandsaw several times a month. I use the cutoff saw once at year, if that.
Happy Woodworking!
R U talkin' abrasive chop saw or band cut-off saw?
Forrest Addy
ScottS
>I looked at abrasive chop saws and decided I didn't like the mess, the sparks, and the stink. Bought what is often called a "dry cut" or "multi cutter" saw: it uses a 14" carbide-toothed blade and spins at about half the speed of the abrasive saw. Cuts are much faster and, in my experience, more accurate than with an abrasive saw. No sparks and the metal doesn't heat up, but it does tend to throw chips everywhere. I find them much easier to clean-up and the fine grit that coats the entire shop after using an abrasive saw.
Unfortunately, you'll pay at least 2X the price (~$400) for the dry cut saw and the blades are extremely expensive ($120+). They'll last for quite a while, and many can be re-sharpened, provided you don't abuse them. I bought the Milwaukee 6190-20. The DeWalt DW872 also gets good reviews, though there seem to be some complaints about the vise.
Re: R U talkin' abrasive chop saw or band cut-off
woodie1
>abrasive chop saw
Jim
>woodie,
I bought my son a metal abrasive chopsaw a while back since he enjoys working with metal.I have to say I can't beleive I waited so long to get one even though it is his. Now since I enjoy it so much I have to go buy another but not for a while since he has another 2 years of college left. If you don't have one please beleive me their well worth the money. But then again this is just my 2 cent worth,
Sincerely
Jim at
Clark Customs
