ADVERTISE HERE - FREE TRIAL
Plywood for shop cabinets
>I am busy designing my shop cabinets. The cabinets will support a counter about 18' long with a 25" space in the center for the miter saw. I was going to make them about 34" or so tall, with the miter saw cabinet being about 3.5" shorter.
I have all the usual hardwood plywoods available. Ash, birch and oak are available in shop grade (as are maple and cherry). I was figuring on using one of these (whichever ended up being cheapest). The cabinets will be face framed with drawer fronts out of whichever hardwood I use. I was also going to try my hand at rail and stile doors.
So, any suggestions as to the "best" plywood to use? Assuming the prices are similar that is.
Re: Plywood for shop cabinets
David Yoho
>I used birch for mine because it's what I had on hand and because it's a smoother grain than an open pored wood veneer like oak. I think for your purpose, the shop grade birch or maple would do just fine.
David
Stephen Kirk in Quakertown PA
>Heck, for the shop I've been using a lot of the sanded pine. It's pretty cheap, generally and when you scratch it all up, you don't really care. Sand to 180, slather on a few coats of poly and it still looks OK.
I disagree on the sanded ply
Pat Evans
>My experience with sanded ply is that it is not as stable enough for cabinets. Drawer fronts in particular are subject to warping.
Re: I disagree on the sanded ply
Pete LaBelle
>Have learned the same. Fir plywood is not as stable as the hardwood veneered plywoods. Has a tendancey to curl and takes effort to work around that.
I guess it depends for your situation whether the cabinet has to be functional, or look good AND be functional.
Re:I want it to look good and be functional..
>I figure I'll have to live with it for a lot of years. That's why I want it to be hardwood plywood.
Don in Northern Arizona
>Jerome,
I have to get some done in the next couple of weeks. I'm going with shop grade birch ply for everything that shows, e.g., visible sides and tops. Fir ply for structural parts that don't show (I have a lot of odd sized pieces that I will get rid of this way). Hardwood for drawer fronts (probably birch). Baltic birch for drawer boxes. The doors with probably be birch ply framed with hardwood.
HTH,
Don
Jay St. Peter - Southern MD
>The "best" is probably baltic birch. But, that doesn't fit my budget for shop cabinets. So, I tend to use borg ply for the shop. I use either birch or sandeply from HD or the Maple from Lowes. None are perfect, but all make real nice shop cabinets. For internal components or light duty shelves I tend to use MDF to save $. I've been unhappy with the results trying to use Luan or "sanded" construction ply. But the backs of my shop cabinets are usually Luan anyway.
Jay
Clay Foster
>Go with what looks good to you. A couple of years from now you won't remember what you paid for the plywood, but you will be living with something you really like or kicking yourself for not going with something better.
As a Norwegian friend of mine says, "Yah, sure, it's a lot of money, but you'll be a long time dead, too."
Paul Kramer
Paul Kramer
>JL,
I used MDO, Medium Density Overlay, for mine. It's the brown paper covered fir plywood. It is very uniform, not too expensive, and smooth. I used the 1/2" and 3/4" stuff covered on both sides. I used the 1/2" stuff for the drawer sides, backs and bottoms and the 3/4" for everything else. I also covered the top with hardboard that's easily replaced and can take quite a bit of abuse.
Paul
