Board support in a planer sled ?
Henry (Raleigh NC)
>Stephen Kirk's reply post in the thread 'WC Weekend Accomplishments' has prompted my question. I have just acquired a planer, and in running a few boards through it I have a new understanding of the phrase "If the first face is not flat, the planed face will not be either." I know this is the reason to get a jointer, but that just isn't going to happen for awhile.
So I am not so much interested in the design of a planer sled, as I can get that from the archives. I am interested in knowing what to use below the planed board in order to support it.
- Do you just use a lot of wedges? If so are the wedges fixed in place? With screws?
- Or do you just use screws in the base at various heights?
- Or is the another option I have not considered?
Thanks,
Henry
Re: Board support in a planer sled ?
>I don't have a planer sled, but have considered making one. I would use wedges. Not screws. I don't like the idea of passing small metal pieces through the planer. Seems like an accident waiting to happen. Also, I suspect the screw heads would leave an imprint on the bottom side. I suppose if you were going to plane that side anyway it might mot matter, but I would rather not mark the wood unless I had to.
None of the above ;-)
Hoa Dinh in Alameda
>Henry,
My jointing "sled" is very simple. It is no sled at all.
This is what I do:
- Use a straight edge and a circular saw to rip straight two sides of the board ("the victim"). The sides don't need to be in parallel.
- Prepare two straight boards of equal size ("the carriers"). Their exact dimensions don't matter much. I'll say they are 3/4" thick, 2" wide, and few inches longer than the victim.
- With screws, attach the carriers to the two straight sides of the victim. The carriers should stand up on the narrow edge (in other words, they are now 2" high). The uneven part of the victim should be slightly above the tops of the carriers. Note that the screws have to be low enough so that they don't chew off the blades of the thickness planer.
- Push the whole thing through the thickness planer, taking a little at the time until you have a flat surface of the victim.
- Remove the carries, flip the victim over and push it through the thickness planer.
A drawback of this method is the screw holes on the side of the victim.
-- Hoa
More none of the above
Neal in San Jose
>People have been flattening and thicknessing boards with hand planes for thousands of years. No need to stop just because Ben Franklin invented electricity! I use hand planes for most lumber, and all boards over 6 inches, since my powered jointer is only a 6 incher. You just have to get it close, then send it thru the planer until the first side is true. Then work on the second side and final dimension. Easier than it sounds, and a lot less fiddley than trying to jury rig shims and wedges.
Stephen Kirk in Quakertown, PA
>I used the idea of a torsion box to get as flat a surface as I could for the sled. Mine isn't perfect, but it's close. To support the board, I put a stop at the front end of the sled. Then, I find which side lays the flattest, put it on the sled and put some shims anywhere it rocks. So far, I've gotten away using a little tape to hold the shims in place. I've heard others use a hot glue gun since it breaks away easily.
The only problem I've seen happening is that sometimes I'm a little more narrow at the ends, almost akin to snipe. If you leave things a little long, no big deal. And, I'm sure with practice I can get rid of that too.
My sled is about 40" long, which lets me put a 36" board on comfortably. I wouldn't want to do a lot of lumber this way, but it works OK for small projects.
Oh, and I hand plane too if the job isn't too large. A jack or scrub can get you reasonably flat pretty fast.
Rick Haverstock
>Henry,
I'm surprised that nobody mentioned the sled that was in Fine Woodworking some time back. (Sorry but all my issues are in storage while I remodel the basement). This is a very nice design and uses wedges that are held in place by drywall screws and sit on a torsion box assembly. Worked very well for me on 7-foot cherry boards for a dining room tabletop. Maybe someone else can chime in and give you the month/issue # of FWW. Good luck.
Rick Haverstock
Hold on just a dogon minute!
>Ben Franklin did not "invent" electricity! He discovered that lightning was electricity!
Electricity existed long before he did!
Re: You're right. Everybody knows...
Al Stokka - Cambrige, Iowa
>...that ALGore invented electricity.
He had to, so he could invent the internet.
Al
Here's the link *LINK*
Stephen Kirk in Quakertown PA
>But membership is required. However, if your interested, it may be the way to go.
Jointing without a jointer
Re: None of the above ;-)
Henry (Raleigh NC)
>Hoa - Thanks for the idea on handling oddly shaped pieces. I should have been more specific in stating that I am interested in face planing. Edge work is something I generally do using a table saw and a sled - using DeStaco type clamps to position and hold the piece.
I have forgotten the source but I have read in some 'planer' thread the idea of ganging many pieces together and running the edges simultaneously in a planer sled in order to assure consistent width. If I had a lot of pieces I'd certainly consider that approach (face frames for a large set of cabinets?), but I typically have less than 5 pieces of anything.
Henry
Maybe I'm not clear...
Hoa Dinh in Alameda
>Henry,
My post is about face jointing. The two pieces (carriers) are to create a reference plane. The upper face of the victim will be made parallel to the reference plane by the thickness planer.
-- Hoa
Re: you're clear...
Henry (Raleigh NC)
>Hoa: Ahh, now I see. I reread your original post, and it was clear enough.
I was just projecting my preconceptions onto this and so I misread it.
Thanks
Henry
>Good Evening Henry,
I used a sled and wedges and screws. Then I bought my jointer. I can't hardly remember being without the jointer. I use it nearly every day. Save your pennies.
George
