200+ woodworking book reviews
Need Help Locating Grinding Wheels
Hank Knight from SC
>I have a 10" heavy duty Sioux bench grinder. The only grinding wheels I can find for it are the gray aluminum oxide ones. Does anybody know if the loose bond fraible wheels are made in a 10" size? If so, where can I find them? I've looked at MSC and McMaster Carr with no luck. TIA
Hank
Re: Need Help Locating Grinding Wheels
Keith Newton
>www.mscdirect.com will have some in that size. The ones that I saw first in that size all had 3" holes.
Try part # 05867700 for a 10" x 1" 46vbe
Thanks Keith - I didn't look far enough
Hank Knight in SC
lots of choices
Bill Tindal, E.TN
>I looked in my large MSC catalog and there were numerous appropriate wheels in the 10" size. For tool steels I Iike a soft bond Norton 25A particle. Unless you are making tools and shaping them I see little need to go to a ceramic particle.
But, you may want to use an 8" wheel to reduce the surface speed. a 10" wheel at 3600 rpm is going to remove metal at a breathtaking rate and control could be an issue.
Thanks, Bill
Hank Knight from SC
>Thanks, Bill. I have been looking under "bench or pedistal grinder wheels." The soft bond ones are apparently listed under "surface grinder wheels," and you're right, there are a lot of choices. My grinder is slow speed - 1725 RPM, so I think I can use the soft bond Nortons with no trouble.
Hank
